On-Chip RAM
Results 1 to 13 of 13
Thread: On-Chip RAM
    Jan 2006
    Istanbul
    Uht-oh,
    I know dyslexia is for numbers, but I think I read that backwards.
    Dyslexia manifests primarily as a difficulty with written language, particularly with reading and spelling. It is separate and distinct from reading difficulties resulting from other causes, such as a non-neurological deficiency with vision or hearing, or from poor or inadequate reading instruction. Evidence also suggests that dyslexia results from differences in how the brain processes written and/or spoken language.
    Dyslexia is most commonly characterized by difficulties with learning how to decode words, to spell, and to read accurately and fluently. Dyslexia also makes mathematics more difficult as people with dyslexia might mix numbers up. Dyslexic individuals often have difficulty "breaking the code" of sound-letter association (the alphabetic principle), and they may also reverse or transpose letters when writing or confuse letters such as b, d, p, q, especially in childhood. However, dyslexia is not a visual problem that involves reading letters or words backwards or upside down, nor are such reversals a defining characteristic of dyslexia.
    And, to whom did you address DT?
    Quote Originally Posted by sayzer View Post
    You, of course.
    I know you know this. Something just got crossed when you were typing it.
    Just re-read post #6. You'll get it.
    Jan 2006
    Istanbul
    You, of course.
    If you are pointing to EEPROM and RAM life, I referred to datasheet stating
    -100,000 write Flash endurance,
    -1,000,000 write EEPROM endurance
    Thus, EEPROM has longer life then RAM.
    If the way I understand it is wrong, please correct me.
    RAM is commonly refered to as "General Purpose Registers".
    That's the area where all the variables are placed.
    Theoretically, you can read or write to RAM every microsecond until the end of time (or the end of the chip, which ever comes first).
    The Flash area is where the program is stored. And the EEPROM is just a place to store periodically changing values that retain their data when power is removed.
    RAM loses it's data when power is removed.
    hth,
    Jan 2006
    Istanbul
    hth,
    Thanks DT.
    In that case, when we use WRITECODE command, are we using up flash life?
    Our friend did not mention losing data.
    Thus, I wanted to add something for his consideration.
    Now you got it.
    And WRITE uses EEPROM life.
    It worked!
  1. Camera with PIC chip
    Last Post: - 1st July 2008, 15:28
  2. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  3. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
  4. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
  5. 18f452 tables in ram - code?
    By rshanks in forum mel PIC BASIC Pro
    Last Post: - 1st October 2004, 06:06
