need help with power inverter
Results 1 to 13 of 13
    Jul 2008
    Default inverter on 16f876
    first forget 12 volt current to high 166 amps
    for 2kv 48 or 60 volts
    i am busy with a inverter at the moment
    what you need is 64 steps 32 first half and 32 second half
    using ccp1 and ccp2
    can supply you basic wave form numbers
    you need voltage check amp check tx loss control all done in loop
    i use a full h bridge driver to give pure sine wave
    mosfet driven.
    the pic is quite busy use 20mhz
    this is just basic
    hope it helps
    Hi there seems if this can become very interesting, is there any change of see-ing the H-bridge circuit for the 2Kva inverter
    Jul 2008
    Default Inverter
    i use the hip 4080
    i would use igbt for 2kv or a lot of mosfets
    you need to use low on resistance type
    the 18f2550 has h bridge but have not tried it
    Jul 2008
    Default inverter on 16f72
    Quote Originally Posted by mikeh View Post
    using ccp1 and ccp2
    hope it helps
    Hi
    I have seen PCBs of sinewave inverter using 16F72. They do not have CCP1 and CCP2 , they only have CCP1 . I wonder how they have done it.
    Sudip
    Jul 2008
    Default Inverter
    As Far As I Know A Full Bridge Is Sine Wave Less Is Mod. Square Wave
    Maybe Some Trick Components.
    Or Using The One Ccp To Gen. Freq. Like You Can Do With A 555
    Jul 2008
    These PCBs are using a full H- Bridge , and the output is a pure sinewave . I have seen the output in an oscilloscope. Four pins of the PIC are being used to drive the mosfets.
    Mar 2008
    Default inverter
    hi guys,
    the technique of using the single ccp on 16f72 is to generate additional square wave called switcher to modulate the sine pwm of the controller, the switcher wave is of the same frequency with the sine pwm wave.this will eventually give the two leg sine signal that can power the h-bridge output.if am less busy i will post a basic schematic of the steering circuits.
    regards,
    babalola.
    Jul 2008
    Hi
    I know about steering circuits and i can make one myself too . But i was telling about these PCB s that they do not have a steering circuits. The four waves needed for the H Bridge is coming from 16F72 . And they have used RC2, RC3, RC5 and RC6.
    Any idea how they are doing it without steering circuits ?
    Sudip
    Feb 2005
    Kolkata-India
    Default Confirm Sudip
    Hi All,
    A compare module can generate software PWM effectively with low ins.cyl overhead. The stearing is all done in software.
    You turn on the pin (according to the steer logic) and with compare interrupt turn off all the outputs. Comapre value comes in from the PID. Turning off the outputs in the ISR and turning them on (sterring) gives you the dead-time automatically. It is not that complicated.
    Sorry can't share the code. (Mostly ASM)
    Sougata
  1. Sine wave power inverter
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2017, 06:16
  2. Power Inverter with PIC
    By tAhm1D in forum Off Topic
    Last Post: - 29th December 2011, 12:14
  3. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  4. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  5. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
