optical voice link
Results 1 to 7 of 7
    Default optical voice link
    Great info, I appreciate the feedback.
    Darrel, how is your PCM method different than PFM?
    I am using a oscillator with an unmodulated 300Khz pulse train, when modulated it deviates the frequency proportional to the audio amplitude. At the receiver I am using a PLL to pull off the audio from the VCO feedback loop.
    Nick
    Quote Originally Posted by Macgman2000 View Post
    That sounds more like plain old FM, where you modulate the frequency of a carrier with an analog signal.
    With PCM, the analog signal is converted to a data stream that can be stored or transmitted like any other data. The data rate is about 1/10th that required by a direct 8-bit A/D conversion, although the quality isn't quite as good, and will probably never match the quality of your FM system.
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 05:03
  2. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 16:09
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. quickBlue™ Link
    By lester in forum Bluetooth
    Last Post: - 20th March 2007, 14:23
  5. Newbie radio link issue
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 05:28
