After bootloading a 16f877a how can i get back rx tx ?
Results 1 to 8 of 8
    Thanks for the reply, did you see my code? i do not now how can i do that can you or other person onder my code explain how i can do it?
    Thanks to all
    by by
    Quote Originally Posted by camolas View Post
    Thanks to all
    by by
    You mean the code attached to post #1? Nope, didn't see it...
    Of course I saw it!
    Re-Read post #2.
    I don't know what your problem is. Seems to me like anybody else would be able to manipulate those pins as they see fit...if the hardware allows it...
    Once you enable the USART, like the Bootloader do, you can't use RX/TX pin with serout. Use HSEROUT instead... OR get rid of all DEFINES, and disable SPEN bit....
    Your program shouldn't finish like that... use STOP of do a loop.
    Hi ive used HSEROUT in my code but dont work, im new at this for other person my be very simple but not for
    Please can you explain me in a beginer mode?
    Is how i used the HSEROUT
    DEFINE LOADER_USED 1
    @ device hs_osc
    define osc 20
    Include "modedefs.bas" ' Include serial modes
    DEFINE HSER_BAUD 9600 'Hser baud rate
    DEFINE HSER_SPBRG 129 'Hser spbrg init
    DEFINE HSER_RCSTA 90h 'Hser receive status init
    DEFINE HSER_TXSTA 24h 'Hser transmit status init
    DEFINE HSER_CLROERR 1
    TrisB.5=0
    TrisC.6=0
    TrisC.7=1
    B0 var byte
    High portb.5
    Pause 500
    Low portb.5
    Pause 500
    High portb.5
    Pause 500
    Low portb.5
    Pause 500
    serout2 portc.6, 32, ["AT", 13]
    serout2 portc.6, 84, ["AT+CMGF=1", 13]
    serout2 portc.6, 84, ["AT+CSCA=+351xxxxx000", 13]
    serout2 portc.6, 84, ["AT+CSCA=+3xxxxxxxxx0", 13]
    serout2 portc.6, 84, ["ola", 13]
    By By
            define OSC 20     ' Check the spelling of OSC, must be in capital letter
            DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
            TrisB.5=0
            TrisC.6=0
            TrisC.7=1
            B0 var byte
            High portb.5
            Pause 500
            Low portb.5
            Pause 500
            High portb.5
            Pause 500
            Low portb.5
            Pause 500
            HSEROUT ["AT", 13]
            HSEROUT ["AT+CMGF=1", 13]
            HSEROUT ["AT+CSCA=+351xxxxx000", 13]
            HSEROUT ["AT+CSCA=+3xxxxxxxxx0", 13]
            HSEROUT ["ola", 13]
            STOP
    Steve it works very well, thanks a lot for the patience to teach a beginer like me.I will learn this one more lesson.
    Sory abouht the box of the code next time i will put it there.
    p.s. If you need same thing from Portugal let me now.
    By BY
  1. Replies: 67
    Last Post: - 8th December 2009, 03:27
  2. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  3. RX - TX timming
    Last Post: - 12th February 2009, 01:06
  4. TX RX Buffer Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 02:49
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
