MCS 3.0.0.5 'bytes used' report sometimes inaccurate.
Results 1 to 9 of 9
    Very interesting.
    Confirmed, using that .inc file with the "New Config" style, it compiles to odd bytes.
    And for more to ponder ...
    I changed the CONFIG's, to the equivelent old style __CONFIG's, and it compiles Even again.
    Go figure.
    ;*  18F4620.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 06/05/06                                        *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
    ;original listing below
    ;       LIST
    ;       LIST p = 18F4620, r = dec, w = -311, w = -230, f = inhx32
    ;        INCLUDE "P18F4620.INC"	; MPASM  Header
    ;        __CONFIG    _CONFIG1H, _OSC_XT_1H
    ;        __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    ;        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
    ;        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ;        NOLIST
    	LIST
        __CONFIG    _CONFIG1H, _OSC_HSPLL_1H & _FCMEN_ON_1H & _IESO_ON_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L & _BORV_0_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_32768_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_PORTC_3H
        __CONFIG    _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
        __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
        __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
        __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
        __CONFIG    _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
        __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
        __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    ;	CONFIG OSC = HSPLL, FCMEN = ON, IESO = ON, PWRT = ON
    ;	CONFIG BOREN = OFF, BORV = 0, WDT = OFF, WDTPS = 32768
    ;	CONFIG MCLRE = ON, LPT1OSC = OFF, PBADEN = OFF
    ;	CONFIG CCP2MX = portc, STVREN = OFF, LVP = OFF
    ;	CONFIG XINST = OFF, DEBUG = OFF, CP0 = OFF, CP1 = OFF
    ;	CONFIG CP2 = OFF, CP3 = OFF, CPB = OFF, CPD = OFF
    ;	CONFIG WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF
    ;	CONFIG WRTB = OFF, WRTC = OFF, WRTD = OFF, EBTR0 = OFF
    ;	CONFIG EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF, EBTRB = OFF
    	NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	64
    Very interesting.
    Oh well, at least we figured out where the extra 1,000 or so bytes is going.
    And besides, odd vs. even.....what's one byte between friends?
    Default MPASM 5.16 report at fault
    I think I found the root cause of the problem. Using MPASM 5.16 from MPLAB 8.02...
    If you look at the bottom of a .lst file, it reports ALL bytes used.
    Consider this cut/paste from the end of one of my .lst files:
    All other memory blocks unused.
    Program Memory Bytes Used: 66451
    Program Memory Bytes Free:  -915
    Errors   :     0
    Warnings :     0 reported,     0 suppressed
    Messages :     0 reported,     6 suppressed
    -951 bytes free? It can't be!
    When I checked the .lst file before, I only looked at the word at the last byte in the actual code itself, I didn't check the last line of the .lst file...
  1. bytes compressed and encrypted
    By RAYMON in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 12:24
