floating point numbers
Results 1 to 11 of 11
    Talking
    Hi, Steve
    NO FP needed ...
    1 Mile = 1619/1006 Km w. Zero error
    1 Mile = 758 / 471 Km w. 1.35 ppm error
    1 Mile = 103 / 64 Km w. 19.3 ppm error
    my favourite :
    Km = Mile */ 412
    Best of ALL
    RTFM , last edition, $ 4.17.1 p.35 ...
    " if you wish to convert miles to kilometers ... etc,etc ..."
    PS: What about THAT ???
    http://www.miscel.dk/MiscEl/miscelIntegerMath.html
    http://www.miscel.dk/MiscEl/miscel.html
    Just to be downloaded ... no ???
    Aug 2007
    for example if i want to do a calculation 80/2.74 = 29.1971
    how would i go about doing this to get the 29.1971 value. i could times up the 80 by 100 but i cant go above 65535 since that is the size of a word. Any ideas on how to get the value of 29.197 so i can times it by a conversion rate?
    Aug 2007
    if i do
    x = 2560/153
    x should = 16.73..... but pbp will see it as 16. therefore i wanted to use the remainder function to get the 0.7
    remainder = 2560 // 153
    but when i print it out on an lcd it says that the remainder is 0. Why is 7 not stored ?
    I see some several ways... which PBP version, which PIC?
    Aug 2007
    its a pic16f77
    pbp version 2.3.0.0 and
    mplab ide v7.60
    many thanks
    Talking
    V2.30 with 16F77 ...
    might provide interesting moments ...
    PBP 2.50a upgrade....only $25....
    How much says the O/P can't get it?
    Well Alain is right this device is not supported in this version... pretty old one i have to say
    Really worth to upgrade everything you have on hand.
    MPLAB is free and now V8.xx
    PBP: now V2.50
    Bombay, India
    Thank you very much for pointing to this very useful utility.
    Jerson
  1. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 22:18
  2. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
  3. ADCin and floating point values
    By niknaksbarbeque in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 12:38
  4. Floating Point
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 15:19
  5. DIV32 instead of floating point routines?
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2004, 08:50
