interrupt with 16F88
Results 1 to 7 of 7
    There are many ways to do Interrupts. But the easiest to use is ON INTERRUPT GOTO.
    To activate a particular interrupt, you'll set the appropriate Enable bit for the interrupt you want to use.
    Then in the interrupt handler you clear the Interrupt Flag before RESUME'ing which returns control to the Main program.
    With more information, we could probably give more direction as to which Enable bits and flags to use.
    Mar 2008
    london
    hello,
    this is a peace of my code, the main routine called main is detecting object and avoiding them and the interrupt subroutine is called start.
    basically its a robot which detect and avoid obstacle (which works fine ) but should jump to a subroutine if either port.b0 or port.b1 or portb2 or portb3 goes low (meaning that an edge is detected) in order to avoid the edge ;and as soon as the 4 portbs '0 to 3' are high together (meaning that no edge is detected) the program should go back to the main routine.
    here is the code:
    '-------------------------interrupt set up ----------------------
    ON INTERRUPT GOTO start
    resume
    '------------------------obstacle mode-----------------------------
    INTCON = %10010000 'enable interrupt on portb.0
    gosub turnhead_extleft 'position head to the left
    position[11] = 0 'reset last position of array to 0
    for i = 0 to 10 'take 11 distance measurements
    gosub sr_sonar 'get sonar readings for each of the 11 dist measuremens
    position[i] = dist_inch 'store sonar reading in the array
    gosub turnhead_right 'rotate head right by 15 degrees
    next i 'do it again
    best_pos = 11 ' ?????
    for i = 0 to 10 'sorting routine to find location
    if position[i] >= position[best_pos] then 'if the distance measured [i] is > than 11 inches
    best_pos = i 'then best position will be that distance i
    serout lcd,baud,[254,135,#best_pos," "]
    next i
    most_space = 11 - best_pos 'number of left positions needed to get the bot head
    'back to position with the most space
    for turn = 1 to most_space 'position the bot head in the direction with the most
    gosub turnhead_left 'free space
    next turn
    for turn = 1 to 15 'walk forward for 15 steps
    gosub sr_sonar 'take sonar readings
    if dist_inch < 6 then 'if obect is too close,ie <6inches
    gosub walk_reverse 'back the bot up for 10 steps
    goto main 'go back to start and scan for the most space again
    gosub walk_forward
    next turn
    '--------------------end obstacle mode------------------------------------------
    '--------------------edge mode-------------------------------------------------
    start:
    if portb.0 = 0 && portb.1 = 0 && portb.2 = 0 && portb.3 = 0 then 'if nothing is detected
    goto do_nothing
    if portb.0 = 0 && portb.1 = 0 && portb.2 = 0 && portb.3 = 1 then 'if left is detected
    goto stop_to_move
    if portb.0 = 0 && portb.1 = 0 && portb.2 = 1 && portb.3 = 0 then 'if right is detected
    goto stop_to_move
    if portb.0 = 0 && portb.1 = 0 && portb.2 = 1 && portb.3 = 1 then 'if right and left are detected
    goto stop_to_move
    if portb.0 = 0 && portb.1 = 1 && portb.2 = 0 && portb.3 = 0 then 'if back is detected
    goto back
    if portb.0 = 0 && portb.1 = 1 && portb.2 = 0 && portb.3 = 1 then 'if back and left are detected
    goto back_headright
    if portb.0 = 0 && portb.1 = 1 && portb.2 = 1 && portb.3 = 0 then
    goto back_headleft
    if portb.0 = 0 && portb.1 = 1 && portb.2 = 1 && portb.3 = 1 then
    goto slow_back_headextright
    if portb.0 = 1 && portb.1 = 0 && portb.2 = 0 && portb.3 = 0 then
    goto front
    if portb.0 = 1 && portb.1 = 0 && portb.2 = 0 && portb.3 = 1 then
    goto front_left
    if portb.0 = 1 && portb.1 = 0 && portb.2 = 1 && portb.3 = 0 then
    goto front_right
    if portb.0 = 1 && portb.1 = 0 && portb.2 = 1 && portb.3 = 1 then
    goto front
    if portb.0 = 1 && portb.1 = 1 && portb.2 = 0 && portb.3 = 0 then
    goto front
    if portb.0 = 1 && portb.1 = 1 && portb.2 = 0 && portb.3 = 1 then
    goto front_left
    if portb.0 = 1 && portb.1 = 1 && portb.2 = 1 && portb.3 = 0 then
    goto front_right
    if portb.0 = 1 && portb.1 = 1 && portb.2 = 1 && portb.3 = 1 then
    goto front
    goto start
    General code flow when using ON_INTERRUPT's...(you mileage may vary, others do it other ways, I do it this way)...
    1) resetplaceholder: 'just a placeholder
    2) ------DEFINEs needed thru the program
    3) DISABLE 'need to disable interrupts while actually processing an interrupt
    4) CLEAR
    5) ------any eeprom data, variable definitions, etc.
    6) ------macro's you might be using
    7) startupholder: goto skipsubs 'skip over all the commonly used subroutines
    8) ON INTERRUPT GOTO INTHANDLER
    9) INTHANDLER: 'process your interrupts.
    10) 'check the interrupt bits, if the interrupt you want is active, reset the bit and process it
    11) INTFINISH: 'I usually recheck the interrupt sources. If one of them tripped while I was processing a previous interrupt, I go back and re-process the interrupt
    12) INTRESUME: RESUME 'resume AFTER you've processed the interrupt
    13) 'commonly used subroutines start below here
    14) commonly_used_sub_1: 'do something here and return from it
    15) ..........
    16) 'end of commonly used subroutines, skipsubs block for setting up registers, lcd, whatever
    17) skipsubs: 'set up the PIC as required
    18) mainloop: 'the main program runs here waiting to get interrupted
    19) ------------more program stuffed in here.........
    20) goto mainloop
    21) END
    Here's some of my advices. Assumming your INTCON an all interrupts settings are nice, i prefer to read the whole PORTB and keep only the revealant bits in one shot.
    INTSOURCE = PORTB & $0F ' this will keep PORTB<3:0> only
    and then you use a Select Case INTSOURCE or BRANCH.
    You forgot the DISABLE/ENABLE RESUME stuff.
    resume
    MIIIIIIIIIIP! that resume will act as a RETURN... and will cause you something like a stack underflow. remove it.
    Read the manual once again.
    Mar 2008
    london
    4) CLEAR
    15) ..........
    20) goto mainloop
    21) END
    hello,
    i wanted to test an interrupt in a simple small code , i found a code on the internet and modified it and got this:
    @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
    OSCCON=%01101000 ' INTRC = 8MHz
    ANSEL=%00000000
    CMCON=%00000111
    OPTION_REG.6=1 'Trigger on rising edge
    INTCON = %10010000 'Enable INTE
    INTCON.1 = 0 'Clear RB0/INT External Interrupt Flag bit
    On Interrupt Goto UpdateCounter
    PORTB=0 ' PORTBs are outputs
    Pause 500 ' Wait for startup
    'LOW PORTB.6
    loop:
    low portb.6
    HIGH PORTB.5
    Pause 2000 ' Wait 2 second
    low portb.6
    LOW PORTB.5
    Goto loop ' Do it forever
    Disable
    UpdateCounter:
    LOW PORTB.5
    HIGH PORTB.6
    low portb.5
    LOW PORTB.6
    INTCON.1=0 're-enable interrupts
    resume
    ENABLE
    GOTO loop
    the code works, but the interrupt routine doesn't work, doesn t light the led connected to pin portb.6.
    I mean when the portb.0 is connected to ground the led connected to portb.5 blinks as soon as i connect the portb.0 to +5v the portb.5 stops to blink and nothing happens to portb.6 led.
    can you help me on that please???
    how can I use a digital signal to activate the interrupt for example, with an if statement??
    if portb.0 = 1 , the interrupt is activated and the program jumps to the int subroutine and if portb.0 = 0 the program comes back to the main loop???????
    thank you
    And yet again, one very important step is missing and one not so important step is also not present...
    No, your code doesn't follow my example exactly, and no, it doesn't have to follow it exactly. Mine is only an example, one of many ways to accomplish the same thing.
    However, I believe in this case, if you follow the example provided, and write your code following said example, you will solve your problem.
    And no, I'm not playing games with you...
  1. Can't ID interrupt source with this IntHandler??
  2. 16f88 interrupt
    By tur_bot in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 12:35
  3. 16F88 Interrupt
    By sskeet in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 16:51
  4. How to use an Interrupt to drive a menu on 16f88
    Last Post: - 15th March 2005, 02:16
