SEROUT being unreliable
Results 1 to 19 of 19
    Perth, Australia
    Actually, i do have 3 interrupts in this program. Maybe SEROUT is getting interrupted and thats messing with the data.
    I'm gonna try disabling the interrupts while I run SEROUT... Not the best long term solution as It wouldnt be good to miss one of those interrupt events, but its worth a try to see if thats whats causing my problem.
    Quote Originally Posted by Kamikaze47 View Post
    Are you using assembly int's (i.e. DT's fast ints) or the ON INTERRUPT types?
    Perth, Australia
    I tried to test the interrupt theory with a simple GIE=0 before SEROUT and GIE=1 after it, but disabling the interrupts makes my program do unexpected things and makes it impossible to test. But i'd say its a high probability that the interrupts are the issue.
    So I guess i'll have to stick with the hardware USART and, as skimask suggested, multiplex its output.
    *edit*: Using ASM interrupts as timing is important.
    Mar 2006
    Pennsylvania, USA.
    I've used serout and debug out to run to two different Double-Talk boards at 9600 baud, both performed perfectly, so I'd have to say that you're right, it's probably the interrupts. I tried it using two different LabX-Usb boards, with 18f4550's, with a DEFINE OSC 48. The boards have 20 Mhz crystals, and the oscillator selection is for HS_PLL.
    Jerry.
    If your oscilloscope costs more than your car...
    Default condition the data line first.
    My serial data errors all went away as soon as I started presetting the data line before transmission.
    For example, RS-232 defines the IDLE or MARK state to be negative volts at the RS-232 connector. That means positive volts at the PIC before the MAX232 inverter.
    Try something like
    HIGH TxData
    pause 2
    Serout/Serout2/Hserout your message.
    It works for me.
    HTH
    BrianT
    Perth, Australia
    BrianT: I previously tried a non-true driven mode and tied the line to +5 with a 10k resistor, which did not help reliability.
    b1arrk5: Yep, in the end I did manage to test it with my interrupts disabled, and it worked, so thats the issue. Disabling the interrupts while I send isn't an option, so no software serial comms for me I guess.
    Perth, Australia
    Ok, i'm looking at the best way of multiplexing the hardware USART's output and this is what I have come up with.
    - Use IC with 4 OR gates (only using 2, but they come with 4).
    - Gate 1: Input1=USART, Input2=A PIC I/O Pin, Output=One of the serial outputs
    - Gate 2: Input1=USART, Input2=Another PIC I/O Pin, Output=Another serial output
    - Use software so that only 1 of the I/O pins is ever high at a time
    I know I could use a NOT gate which would allow me to use only 1 I/O Pin, but i'd rather use another I/O pin than add another IC.
    If anyone can see how this can be done better (and still only using the PIC + 1 IC), feel free to share.
    That's exactly what I was talking about. If you wanted to get rid of the 7402 (?), you could easily do the same thing with a couple of 2N2222's.
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
    Last Post: - 13th December 2008, 17:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 04:26
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
