Interrupt problem ?
Results 1 to 5 of 5
    Exclamation Interrupt problem ?
    Hi all,
    I have a strange problem and if any one have the solution or the idea to solve it
    first I interface the barcode reader with PIC16f877a which when anyone pass its ID card it will display the number on the LCD without any problems and it's working alright.
    second I interface my HP laseject printer with pic16f877a so I can print some information on printer and it's working alright without any problems.
    Now I want to mix two steps since when anyone pass its ID card , the printer will automatically print the ID number.
    I did first step and second step individual without any problems, but when i mix the two steps together in one file , the printer worked but the interrupt doesn't work since the number is not true.
    I don't know why the interrupt is not woking properly
    Quote Originally Posted by iugmoh View Post
    Neither will we unless some code starts magically appearing...
    Oky it's now woking since I replace gosub with the code itself , but i don't know what is the reason
    Don't post you code just in case we could help
    You're using a 16F877A...
    If you check the PBP manual, you might see where it says that you can only nest a GOSUB so many levels deep. Maybe that was your problem...
    You 'overnested' your GOSUBs and caused a stack overflow, which caused the program to either crash or reset.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
