Expanding Timer1 counting range
Results 1 to 15 of 15
    Post
    Your LCD display is unable to show time for EACH ms ... the LCDOUT command needs much more thant 1 ms - OR you should use LED Display ...
    With that way of programming You might have enough time to refresh the display between two interrupts ...
    Here, to be accurate ... you just can display exact time ONLY once timer stopped !!!
    see How Darrel's "Elapsed timer Demo " works ... and you will be able to see "intermediate time"
    http://www.picbasic.co.uk/forum/show...=Elapsed+timer
    PS: you can read the ms "on the fly" .... Wooowww !!! you got a fantastic pair of eyes !!!
    LOL ...
    Dec 2007
    Malaysia
    The additional line of code after the clear overflow flag is to test the timer whether the timing is accurate or not. Let's say of ms can't be seen, but at least for the seconds can be seen accurately right? Previously the coding was to display the final value directly on the LCD after Stop button is pressed. Conclusion is, I wonder the 1ms interval can be achieved or not.
    From my codes structure, is achieving 1ms interval timing possible? Is there any modification need to be carried out besides displaying final timing value on LCD, in order to achieve 1ms interval timing?
    Actually, most of the LCDs I've got, usually the 16x2, are able to handle a commandus of around 100 and a dataus of 50 (the best one I've got will do commandus = 50 and dataus = 27, well below that datasheet values).
    So, assuming you don't have too much to display, theoretically, you could refresh one complete line on a 16x2 LCD inside of 1ms...assuming that is
    (and I knew this thread was coming)
    Dec 2007
    Malaysia
    Is that mean the culprit for unable to get 1ms interval timer is the LCD display? What is I just make it display the final value upon stop button is pressed? Can this solve the problem?
    Quote Originally Posted by sycluap View Post
    Are you completely incapable of doing any 'out of the box' thinking? Kick your brain into gear! Just because the LCD takes longer than 1ms to display (which is not necessarily true, but at default settings is true), doesn't mean the PIC can't keep counting until you stop it from counting and then displaying the result when it is done counting.
    What are you counting that supposedly requires microsecond accuracy anyways?
    Dec 2007
    Malaysia
    Not that I can't think out of the box, but I've asked around and tried whatever is possible, to display counting in LCD, not to display in LCD, to display only the final value, etc, but i still can't manage to get the timer to display in 1ms timing interval. I know that the PIC can continue counting by itself, but, even I try to make it display only the final value, but it still can't display the accurate readings.
    Sorry for asking questions that might consider too easy for some others, but I am totally new in this. I need the timer to measure the human response time.
    MY CODE:
    'MAIN PROGRAM
    ResetTimer:
    GoSub SetReg
    LCDOUT $FE, 1
    Timer1H = 0
    Timer1L = 0
    MicroThousandths = 0
    Thousandths = 0
    Hundredths =0
    Seconds = 0
    LCDOUT $FE, $80, "Test Mode 1"
    'LCDOUT $FE, $C0, "Visual Response Test"
    If ButStart = 1 Then goto StartTimer
    Goto Main
    StartTimer:
    LCDOUT $Fe, 1
    LCDOUT $FE, $80, "Calculating..."
    T1CON.0=1
    Looping:
    While PIR1.0=0
    Wend
    PIR1.0=0
    Thousandths=Thousandths+1
    If Thousandths>9 Then
    Thousandths=0
    Hundredths=Hundredths+1
    If Hundredths>99 Then
    Hundredths=0
    Seconds=Seconds+1
    Endif
    Endif
    If ButStop = 1 Then goto StopTimer
    Goto Looping
    StopTimer:
    T1CON.0 = 0
    LCDOUT $Fe, 1
    GoSub GetValue
    DisplayResult:
    LCDOUT $FE, $80, "Time Elapsed"
    LCDOUT $FE,$C0, dec2 Seconds, ".", dec2 Hundredths, ":", dec Thousandths
    If ButReset = 1 Then goto ResetTimer
    goto DisplayResult
    'SUBROUTINES
    'Get value from Timer1 Register
    GetValue:
    Timer1H=TMR1H
    Timer1L=TMR1L
    'Reset Timer1 Register to Start from 1ms interval
    SetReg:
    TMR1H = $FC
    TMR1L = $18
    Now, what is wrong with my codes? Correct me please.
    Not that I can't think out of the box......
    Big hints for you back in post's #5 and #7.
    I think you're way over-doing this in the first place.
    So, what you want is a program to start counting when you hit one button, and stop counting when you hit a second button, and display the time interval between the 2 right?
    some generic code (you fill in the crap with real code)
    'Set up all variables, registers, timers, etc... No interrupts
    'display start message
    'wait for start button to be hit, if it's not hit, don't jump back to the lcdout display command
    'takes time to display and might miss a button push in the meanwhile
    'if the button is hit, reset tmr1 to zero and start the timer
    'start a loop
    'display the current count (which will take longer than 1ms, but the next bunch will take care of that, again, the problem with displaying stuff during a tight count is that you will miss the exact time that a button is pushed and the count could possibly be off by 1 or 2 ms)
    'if the tmr1 value is above 1000, add 1 to the ms counter and subtract 1000 from tmr1 (3 from tmr1h and 232 from tmr1l, or subtract 4 from tmr1h and add 24 to a subcounter to cover the extra 24us.  when that subcounter exceeds 1000, add another one to the ms counter
    'check the stop button
    'if the stop button is not pushed, jump back to the loop
    'if the stop button is pushed, immediately save the tmr1 count, do the 'over 1000' math to keep the ms count and us count, and display the total
    No, not real code, an outline as a guide.
    Interrupts are nice, and DT interrupts and the Olympic timer are all you need, but apparently it's not enough to have almost 100% pre-written code made just for you.
    This code is based on the fact that you keep timer1 BELOW a certain value and keep track of it as it counts UP. That way if you miss a count or two, you can always recheck it (i.e. tmr1 is 3000, you've missed 3ms, no biggie, just subtract 1000 from it 3 times and you're back on track). I built an OBD2 reader that's based off this to drive my virtual odometer, integrates time and speed. In the process of reading the OBD2 message, I miss a count here and there. No problem, just let the counter increase in the background and cover it up later. The intervals are short enough that I get a nice accurate reading (within 1/10 mile over a 263 mile drive 2 weeks ago) and long enough that the timer won't overflow in between readings.
    Make any sense yet?
    Dec 2007
    Malaysia
    Thanks for the guide. I have clearer idea now. Sorry for OVERDOING it. But at least Mr.Skimask and Mr.Acetronics is willing to help me out. Thanks.
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 11:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 15:07
  3. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 00:31
  4. continious counting process (capture)
    By asynch in forum General
    Last Post: - 17th February 2006, 07:42
  5. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 01:24
