While we're on the subject of optimization...
Results 1 to 32 of 32
    mmpff, to me it doesn't make sense at all to do so, this will just suck juice where it shouldn't need to. I would just prefer to use a macro for the color stuff, and one for the print... or filling the whole thing with all parameter in. but, yeah, that's me
    I guess my main thing is that I can put the whole thing into one command.
    Instead of this:
    lcdpx = 10
    lcdpy = 10
    string = "assuming PBP could handle strings anyways"
    forecolor = 5
    backcolor = 0
    I get this:
    @ printstr "10,10,printstr can handle this string after all,5,0"
    Might not save any code space, but I can see it saving some sanity...
    Aug 2005
    Michigan, USA
    I've used the following method in assembly language programs to reduce LCD string "overhead" by pulling the string address from the stack but I'm not sure how you might implement it in PBP (or if it might save memory compared to how you're doin' it now).
    Food for thought. Regards, Mike
    ;  example macro usage
            PutStr  "Azimuth:\n\r "
            PutStr  "Elevation:\n\r"
    ;  PutStr macro
    PutStr  macro   str             ; print in-line string
            call    PutString       ;
            db      str,0
            ENDM
    ;  PutString - print in-line string via Stack and TBLPTR
    ;  string must be terminated with a 00 byte and does not need
    ;  to be word aligned
    PutString
            movff   TOSL,TBLPTRL    ; copy return address into TBLPTR
            movff   TOSH,TBLPTRH    ;
            clrf	TBLPTRU		; assume PIC with < 64-KB
    PutNext
            tblrd   *+              ; get in-line string character
            movf    TABLAT,W        ; last character (00)?
            bz      PutExit         ; yes, exit, else
            rcall   PutLCD          ; print character to LCD
            bra     PutNext         ; and do another
    PutExit
            btfsc   TBLPTRL,0       ; odd address?
            tblrd   *+              ; yes, make it even (fix PC)
            movf    TBLPTRH,W       ; setup new return address
            movwf   TOSH            ;
            movf    TBLPTRL,W       ;
            movwf   TOSL            ;
            return                  ;
    How's this for losing some sanity?
    In case someone opens that file, and is running a little short...
    Here's an extra roll for ya.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2403&stc=1&d=120519801 7" />
    Thanks Darrel. I sure needed the extra roll!
    Hey Skimask, are you really able to follow the program? I got dizzy... Congrats anyway!
    I suppose it's like anything else when programming...the guy that wrote it can follow it, practically nobody else can...
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. code size VS speed optimization setting?
    Last Post: - 28th April 2008, 15:38
  3. Multiple if then optimization
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 13:15
  4. Replies: 2
    Last Post: - 1st May 2006, 14:45
