rfPIC Serin problem
Results 1 to 40 of 53
    medusa2584,
    Recheck your code flow.
    You're still trying to RETURN from GOTO in various places.
    And (I'm not even sure if it's possible in MPLAB) are you getting stack OVERFLOW errors or stack UNDERFLOW errors? If getting UNDERFLOW is possible, that's what I'd say you're getting.
    Nov 2007
    thanks skimask. i solved the the underflow and overflow program. however, i got a new problem.
    when i tested my program with rfpic12f675, and put probe at gp2 and gp5. the output is similar with what i simulated in mplab sim. there is preamble, header, and data bits. however, there is no change of output displayed on the oscilloscope even i dont supply any input to the transmitter. any suggestion why this happened?
    the output always showed data bit of 1111 0111 which is weird since i sont supply any input to the system.
    any suggestion anyone?
    T.Jackson's Avatar
    T.Jackson Guest
    medusa2584,
    Hello skimask,
    I'd like to take this opportunity to welcome you back to the forum. I do hope that your stay will be a long, pleasant & fruitful one. Everyone deserves a second chance
    Nov 2007
    I was simulating my program and did not even finish running everything - my MPlab just suddenly close itself with a window Microsoft is checking the problem.
    Does anyone know why? Is that because of my Vista or because of the bug in the
    new version MPLab IDe 8?
    Check out the Microchip forum, i remember to have already heard about some strange problem using Vista.
    http://forum.microchip.com/tt.aspx?forumid=57
    PS: you have 'till January to buy an XP o/s... to me, Vista is really not recommended before, at very least, 1 year...
    Nov 2007
    I suppose that might be the problem. I'll try simulating that on XP based first then.
    I need some help with understanding the rate of data in programming the receiver rfrxd420 using pic16f676.
    The demo program currently indicates that the the TMRHIGH and TMRLOW to be multiply with 4us. Does this relates to the baud rate?
    I'm having problem to understand the timing of the program.
    Can anyone help?
    Hello skimask,
    2nd chance?
    2nd chance at what?
    Did I lose my first chance at something?
    Did you have something to do with afford me a second chance at whatever it is?
    Did I go somewhere else that I needed to come back?
    Howdy skimask, good to hear from you again.
    T.Jackson's Avatar
    T.Jackson Guest
    2nd chance?
    2nd chance at what?
    I see that someone is experiencing some considerable "self-denial".
    Time for someone else to step outside and play a one-handed game of hide and go @$%&# one's self...and deny some of that...
  1. Serin Problem with 12F629/PBP
    By Flyingms in forum mel PIC BASIC Pro
    Last Post: - 9th March 2009, 14:59
  2. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 22:50
  3. Serin serout problem
    Last Post: - 6th February 2007, 04:25
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  5. serout and serin problem
    Last Post: - 11th April 2006, 19:44
