USB Optical mouse as motor encoder
Results 1 to 7 of 7
Threaded View
  1. #2
    Default The part i dont get about USB yet
    Hola Rodstar
    Well i'm sure you have worked around USB devices a lot more than i have since i just made my first steps, and must surely i am wrong, and you can clear a black hole in my mind but..... USB is not as simple bidirectional comunication as RS232. What i mean is that you might need a USB host controller in order to connect USB devices to it (PC brings one), with PIC micros you can only make devices to be connected since it doesnt have the host controller, so you can't connect a USB mouse to a PIC and expect to receive the data.
    On the other hand it would be really usefull to emulate someway the controller behavior with the pic since you can find tons of ideas where a USB device is controlled by a uC. I am just considering USB cameras(cheap), uSB keyboard, MOUSE, USB memory for storage, etc. I had this same question in the USB demo by mister_e asked sometime ago, someone there proposed a small device that could be used to control USB things but it was external and far away from Colombia and Chile .
    check this:
    http://dataweek.co.za/news.aspx?pklN...lCategoryID=34
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  3. Using the optical sensor from a ball mouse
    By lsteele in forum General
    Last Post: - 5th September 2007, 16:45
  4. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
  5. USB on Macintosh (mouse)
    By ronf in forum USB
    Last Post: - 19th October 2005, 14:29
