A Little surprise with PbP 2.50 ...
Results 1 to 31 of 31
    Smile The official answer ...
    Hi, Bruce,
    thanks for your enlightments.
    find here the answer from Melabs :
    For special characters such as this, it is better to specify the
    character using its numeric ASCII code. I believe this will work:
    LCDOUT $FE,$C0," ", SDEC2 Tair, $B0, "C "
    I believe you could ignore the warning and the display would be
    correct, but it's always a good idea to resolve warnings as they come
    up.
    Charles Leo
    microEngineering Labs, Inc. "
    Solution confirmed ... and thanks to melabs.
    Assuming Tair = 32d;
    Which version prints 32°C on your LCD?
    or;
    LCDOUT $FE,$C0," ", SDEC2 Tair, $DF, "C "
    or;
    LCDOUT $FE,$C0," ", SDEC2 Tair, 223, "C "
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hangover, Germany
    My guess: b)
    or;
    or;
    Hi, Bruce
    Seems Charles made a little mix ...
    Works fine on my testboard with every release ... and shows " xx°C " ( xx is SDEC2 Tair )
    The special character code ( use HEX !!! ) is to read from your Display Datasheet table.
    Well, if $DF works then 223 will work too, isn't it?
    P.S. to Alain. Have you seen the image of the LCDOUT command that I posted on #13? Is this what you typed?
    Wink
    Hi, Ioannis
    > I don't know ... exactly, I don't remember !!! ... the code is given in HEX in the Displays Datasheets ... may be the reason is here !!!
    > Will give a TRY in the following minutes ...
    >> EXACTLY !!!
    Have a nice day
    PS: I saw the "Parthenon" had lost some altitude ... Gods will be furious ...
    I am sure some believers of the old religion will be furious. As for the "gods", I really don't care! They were too human!
    Just being curious, what is the meaning of the symbols you were trying to display? I mean OK with the degrees symbol, but the other two?
    Talking
    QUOTE=Ioannis;I am sure some believers of the old religion will be furious. As for the "gods", I really don't care! They were too human!
    Hé,hé ... the egg ... or the Hen ..
    The " ö " is mainly used by people from north Europe
    The " µ " ...do not tell me you don't know microfarads ... or µFarads !!!
    Both belong to the High part of the Character table ... good reason to use them here .... no ????
    An Overall ... µ ( mikro) comes from ancient GREEK alphabet ( alpha, beta, delta, epsillon ...etc. )Boooooooooooooooooooooooo !!!!
    Mar 2006
    China
    Default Never heard of Å Ä Ö å ä ö??
    Å Ä Ö (å ä ö) are the last 3 lettters in the Swedish alphabet. They are very useful since it is impossible to spell beer without Ö ---> ÖL
    They are common letters but we can do without them if we really have to :-)
    /me
    Sep 2006
    Default Thanks for the solution
    Hi, Bruce,
    up.
    Charles Leo
    Taking note.....
  1. PBP 2.50 and Longs
    By mikendee in forum GPS
    Last Post: - 21st May 2008, 22:16
  2. PBP 2.50 UPGRADE problems!!!!
    Last Post: - 7th March 2008, 16:42
  3. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 21:45
  4. MCS+ with PBP 2.50
    Last Post: - 21st September 2007, 06:52
  5. New PBP 2.50?
    By Dave in forum mel PIC BASIC Pro
    Last Post: - 9th September 2007, 20:14
