truck gate
Results 1 to 13 of 13
Thread: truck gate
    What about power failure?
    Thats easy...The gate don't work!
    :-) Good one! But I meant that the phase sequence will be lost on power failure.
    Anyway Melanie gave the absolute solution. So, as she stated, next problem?
    Jul 2005
    Midwest
    I have a question/problem.
    Is there an effective way to deal with a person who doesn't know what they don't know?
    Been driving me crazy for years.
    -Steve
    Quote Originally Posted by Steve_88 View Post
    -Steve
    Make them a VP of something.
    Aug 2005
    down south
    Melrso here is a program I did for a door controller sometime back
    I spent about 15 mins. modifing *** it to do what I think you asking
    (I left all the extras that I needed)
    I have not tested the mod. only compiled. it's a lot of code to do so little
    but you get what you pay for and this is free. after 3 years I'm still a newbie
    as we say down south maybe this will prime your pump
    chow
    grounded
    '* Name : GATE.BAS *
    '* Author : GROUNDED *
    '* Notice : Copyright (c) 2007 HAVING FUN PROGRAMMING *
    '* : All Rights Reserved *
    '* Date : 1/11/2006 /10-12-07 *
    '* Version : 1.0 ***MOD. FOR GATE CLOSER *
    '* Notes : DRIVE THOUGH DOOR WITH PHOTO EYE, REVERSING EDGE *
    '* & AJAR SAFETY SWITCHS . ONE PUSH BUTTON FOR OPEN/CLOSE *
    'WITH FAULT CODE (FLASHING LED) *
    'PHOTO EYE FAULT CODE LED 4 SEC. ON 4 SEC. OFF *
    'REVERSING EDGE FAULT CODE LED ON 1 SEC OFF 1 SEC ON 1 SEC. OFF 4 SE
    'AJAR FAULT CODE LED ON 1/4 SEC. OFF 1/4 SEC. ON 1/4 SEC. OFF 4 SEC.
    'FAULT DOES NOT RESET WITH POWER RECYCLE MUST PUSH RESET BUTTON
    'COMPILED @ 389 WORDS
    '** ADDED FOR GATE CONTROLLER REVERSE OPERATION ON PB PUSH *
    pic16f630
    'FUSES SET IN INC. FILE
    'INTRC_OSC_NOCLKOUT, WDT_ON, MCLR_OFF,
    'CPD_OFF, BOD_OFF, PWRT_ON,PROTECT_OFF
    Pause 7000 'DELAY TO LET STABILIZE AFTER POWER UP
    CMCON = 7 'COMPARATOR OFF
    VRCON = 0 'VOLTAGE REF. DISABLE
    TRISA = %00011111 'MAKE ALL BUT A.5 INPUTS
    TRISC = %00110000 'MAKE PORTC .4,.5 INPUT REST OUTPUTS
    OPTION_REG=%01000000 'ENABLE WEEK PULLUPS (CLEAR RAPU)& RISIING EDGE
    WPUA = %00010011 'WEAK PULLUPS ON PORTA..0,.1,.4,
    SYMBOL OL = PORTA.0 'OPEN LIMIT SW.IN 3
    SYMBOL CL = PORTA.1 'CLOSED LIMIT SW.IN 4
    SYMBOL PB = PORTA.2 'OPEN/CLOSE PB IN 1
    SYMBOL RS = PORTA.3 'FAULT RESET IN 2 RESET
    SYMBOL PE = PORTA.4 'PHOTO EYE IN 5
    SYMBOL LED = PORTA.5 'POWER UP & FAULT LED OUT 3
    SYMBOL CDC = PORTC.0 'CLOSE DOOR CONTACTOR OUT 1
    SYMBOL ODC = PORTC.1 'OPEN DOOR CONTACTOR OUT 2
    SYMBOL NA = PORTC.2 'N/A
    SYMBOL NAA = PORTC.3 'N/A
    SYMBOL RE = PORTC.4 'REVERSING EDGE IN 6
    SYMBOL AJ = PORTC.5 'AJAR SWITCH IN 7
    FR VAR BYTE 'FAULT VAR
    PEC VAR BYTE 'PHOTO EYE FAULT CODE
    REC VAR BYTE 'REVERSING EDGE FAULT CODE
    AJC VAR BYTE 'AJAR FAULT CODE
    OL=0:CL=0:PB=0:RS=0:PE=0:LED=0:CDC=0:ODC=0:NA=0:NA A=0:RE=0:AJ=0
    LED=1 :PAUSE 2000 :LED=0 'POWER UP LED
    MAIN:
    IF fr=1 then goto fault 'CHECK FOR FAULT AFTER POWER UP
    'LOOP UNTIL OPEN /CLOSED PUSH BUTTON IS PUSHED
    IF PB=1 THEN PAUSE 10000 : GOTO CHECKIT'***10 SEC. TO RELEASE PB
    PAUSE 250
    GOTO MAIN
    CHECKIT:
    IF (OL=0) AND (CL=0) THEN GOTO OPENUP 'IF NO LIMIT SW. MADE THEN OPEN (COULD USE CLOSE)
    IF (OL=0) AND (CL=1) THEN GOTO OPENUP 'IF CLOSE LIMIT SW. MADE THEN OPEN
    IF (OL=1) AND (CL=0) THEN GOTO CLOSE 'IF OPEN LIMIT SW. MADE THEN CLOSE
    RELO: '*******
    PAUSE 100
    IF PB=0 THEN GOTO EOPEN '** PB MUST BE RELEASED BEFORE DOOR WILL START OPENING
    GOTO RELO
    EOPEN:
    IF PB=1 THEN GOTO OPENUP'***LOOP UNTIL PB IS PUSHED THEN OPEN
    GOTO EOPEN
    OPENUP:
    IF (FR=0) AND (OL=0) THEN ODC=1 'IF NO FAULT & OPEN LIMIT NOT MADE OPEN
    IF PB =1 THEN ODC=0:PAUSE 3000: GOTO RELC '***IF PB PUSHED STOP AND THEN CLOSE
    IF OL=1 THEN ODC=0 : GOTO MAIN 'WHEN DOOR FULLY OPENS GOTO MAIN
    GOTO OPENUP 'LOOP UNTIL OPEN LIMIT IS MADE
    RELC:
    PAUSE 100
    IF PB=0 THEN GOTO ECLOSE '***PB MUST BE RELEASED BEFORE START CLOSING
    GOTO RELC
    ECLOSE:
    IF PB=1 THEN GOTO CLOSE '**** LOOP UNTIL PB IS PUSHED THEN START CLOSING
    GOTO ECLOSE
    CLOSE:
    CDC=1 'CLOSE DOOR CONTACT
    'IF PHOTO EYE OR REVERSING EDGE IS TRIPP WHEN DOOR IS CLOSING STOP AND THEN OPEN
    IF PB=1 THEN CDC=0 :PAUSE 3000 :GOTO RELO '**IF PB PUSHED STOP AND THEN OPEN
    IF CL=1 THEN CDC=0 :GOTO MAIN 'LOOP UNTIL CLOSE LIMIT IS MADE
    IF PE=1 THEN PEC=2: CDC=0 :PAUSE 4000 :GOTO FO 'PHOTO EYE FAULT
    IF RE=1 THEN REC=2: CDC=0 :PAUSE 4000 :GOTO FO 'REVERSING EDGE FAULT
    IF AJ=1 THEN AJC=2: CDC=0 :PAUSE 1000 :GOTO FAULT 'AJAR FAULT
    GOTO CLOSE 'LOOP AND CHECK FOR FAULT
    FO: 'IF YOU HAVE A PE OR RE FAULT OPEN DOOR AND
    'THEN SHOW FAULT
    IF OL =0 THEN ODC=1
    IF OL=1 THEN GOTO FAULT
    GOTO FO
    FAULT:
    FR=1
    IF PEC=>2 THEN LED=1:PAUSE 4000 :LED=0 :PAUSE 4000
    IF REC=>2 THEN LED=1:PAUSE 1000:LED=0:PAUSE 1000:LED=1:PAUSE 1000:LED=0:PAUSE 4000
    IF AJC=>2 THEN LED=1:PAUSE 250:LED=0:PAUSE 250:LED=1:PAUSE 250:LED=0:PAUSE 4000
    IF RS=1 THEN PEC=0: REC=0 :AJC=0 : FR=0 :GOTO MAIN
    GOTO FAULT
  1. Sine wave power inverter
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2017, 05:16
  2. A logic gate chip with 1 ea XOR and 2 ea AND gates?
    Last Post: - 5th August 2009, 05:29
  3. MOSFET driver
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 22:07
  4. Combinaton Gate access
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2007, 01:20
  5. HPWM problem .. pls help!
    By Samuel in forum mel PIC BASIC Pro
    Last Post: - 1st February 2006, 15:30
