Variant of Serin2/Timeout Hang Problem
Results 1 to 4 of 4
    well... first observations,
    i don't see any DISABLE and ENABLE 'round the ISR.
    RESUME should not be followed by a label name,
    and you don't reset the INT bit.
    So yes it may cause some weirdnessssssssss.
    And the following will explain when using pull-up/down for serin and timeout
    http://www.picbasic.co.uk/forum/show...86&postcount=5
    Sep 2007
    Default Variant of Serin2/Timeout Hang Problem
    I'd been commenting things in and out for awhile, so my example
    wasn't complete. My bad ...
    Yes, DISABLE INTERRUPT was in there at the beginning of the ISR
    "The INT bit" ... I suppose you're refering to INTCON.1 ... yes, it gets
    cleared first thing in the ISR as well. This wasn't explicitly mentioned
    in the manual, the assumption being that DISABLE INTERRUPT would
    cope with multiple hits to the int pin. Nope.
    I removed the label from "RESUME" ... but it didn't make any difference.
    Actually, that IS a legal syntax. You can resume to any label, not just
    to where you started from.
    I also tried changing the literal milliseconds timeout value to a CON and
    then a VAR just in case Serin2 didn't LIKE literals.
    Alas, no joy. Still refuses to timeout when the input pin is held low, still
    causes the chip to hard reset when the pin is high. Very frustrating.
    I'd done quite a number of PBP programs before ... with plenty use of
    the serial OUTPUT statements, but this is the first time I've tried to get
    serial data IN ... and it's not looking hopeful. I even tried a new 'F88
    chip just in case I'd somehow fried the first one. Could the 'F88 be
    "special", some flag needing to be set that got missed by the PBP
    compiler writers ?
    Hmmm ... the 'F88 *does* have hardware USARTs. I wonder if going
    to the HSERIN/HSERIN2 statements might have an effect ? Somehow
    though I suspect the logic is exactly the same past a certain point.
    Any more ideas/links/abuse/lottery_numbers/etc ?
    -Jimbo
    Sep 2007
    Useful new information :
    Switching to HSERIN solved two problems at one stroke.
    The timeout now works correctly AND it doesn't make any
    difference whether the input pin is high or low (just so long
    as it isn't noisy).
    There are a couple of remaining issues with HSEROUT, primary
    being that it's sometimes "tardy" about outputting a character,
    waiting until another "pushes it out" - presumably out of a small
    buffer. Alas it's one of those evil "sometimes" problems - sometimes
    the character prints promptly, sometimes it doesn't - which makes
    a generic 'dump your buffer' solution difficult. I may just have to
    add extra, pointless, characters to the output.
    The timeout seems to run fast also ... maybe 30% ... although
    PAUSE() statements time perfectly. This isn't a biggie.
    Of course none of this will help people using chips without an
    internal USART. I wonder if the USART somehow interferred
    with using my chosen I/O pins for the SERIN2 command ? I'm
    pretty sure I'd disabled anything to do with it, the chip should
    have responded as if it were an 'F84 ... should have. Lots of
    subtle, poorly documented, interactions in these things however.
    Anyway, I think I can proceed with my app now. I really didn't
    want to change it over to CC5X just to get around one little
    issue like this. Besides, I'd have to write more complex ISR
    and serial routines in that language ...
    - Jimbo
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
