@Darrel Taylor Interrupt ;-)
Results 1 to 11 of 11
    Jun 2007
    Germany
    Default @Darrel Taylor Interrupt ;-)
    Hi Darrel,
    iīm using your last interrupt posting to me for a 16F913. But something is not working just like at the 16F872. I read the datasheet for the 16F913 and i think itīs the same parameter like 16F872.
    I set all PORTS to DIGITAL I/O (this was really hard to find out for this device). I think they are ok so.
    Maybe you know why the interrupt is not working.
    DEFINE OSC 8
    ADCON1 = %111
    ANSEL = 0
    CMCON0 = 7
    LCDCON = %01000000
    LCDSE0 = 0
    LCDSE1 = 0
    @ERRORLEVEL -306
    RBCPins     VAR Byte
    LastPins    VAR Byte
    Lastpins =  PORTB
    INTCON.0 = 0
    INTCON.3 = 1
    TRISA = %00111000       ' RA0-2 OUT, RA3-5 INPUT
    TRISB = %11100000       ' RB7 & RB6 PORTChange by Interrupt, RB5 Input Clicker as Input is not needed for Interrupt change
    TRISC = %00000000
    ON INTERRUPT GOTO MyINT
    GOTO Main
    DISABLE
    MyINT:
    RBCpins = PORTB
    IF RBCpins.7 <> Lastpins.7 THEN
        DPO2 = 0
        PAUSE 20
        DPO1 = 0
        PAUSE 40
        DPO2 = 1
        DPO1 = 1
    IF RBCpins.6 <> Lastpins.6 THEN
        DPO1 = 0
        PAUSE 20
        DPO2 = 0
        PAUSE 40
        DPO1 = 1
        DPO2 = 1
    INTCON.0 = 0
    RESUME
    ENABLE
    thx Robson
    Maybe ....
        Lastpins.7 = RBCpins.7
        DPO2 = 0
        PAUSE 20
        DPO1 = 0
        PAUSE 40
        DPO2 = 1
        DPO1 = 1
        Lastpins.6 = RBCpins.6
        DPO1 = 0
        PAUSE 20
        DPO2 = 0
        PAUSE 40
        DPO1 = 1
        DPO2 = 1
    Are you setting INTCON.GIE somewhere not shown?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    That Horrible Nasty Wicked ON INTERRUPT sets GIE for you.
    Hmm! Maybe one more reason I don't use it...;o}
    -Bruce
    tech at rentron.com
    Here's another reason ...,
    You can't turn GIE off. If you do, it jumps to the handler then turns GIE back on.
    LED1  VAR PORTB.0
        PAUSE 500
        INTCON.7 = 0
    GOTO Main
    DISABLE
    MyINT:
        TOGGLE LED1
    RESUME
    That will flash the LED via the Interrupt handler, even though no interrupts have occured.
    One more reason to use DT-INTS ehh..;o}
    BTW: Nice work on the new interrupt routines Darrel. Most impressive.
    -Bruce
    tech at rentron.com
    Jun 2007
    Germany
    Itīs not working. The INTCON registers seems to be the same, but nothing happens to PORTB change...
    Oh i didnīt see your last post.
    Is it not possible to work like before with RBCPins ... ?
    What does Note1 means?
    bit 7 GIE: Global Interrupt Enable bit
    1 = Enables all unmasked interrupts
    0 = Disables all interrupts
    bit 6 PEIE: Peripheral Interrupt Enable bit
    1 = Enables all unmasked peripheral interrupts
    0 = Disables all peripheral interrupts
    bit 5 T0IE: Timer0 Overflow Interrupt Enable bit
    1 = Enables the Timer0 interrupt
    0 = Disables the Timer0 interrupt
    bit 4 INTE: RB0/INT External Interrupt Enable bit
    1 = Enables the RB0/INT external interrupt
    0 = Disables the RB0/INT external interrupt
    bit 3 RBIE: PORTB Change Interrupt Enable bit(1)
    1 = Enables the PORTB change interrupt
    0 = Disables the PORTB change interrupt
    bit 2 T0IF: Timer0 Overflow Interrupt Flag bit(2)
    1 = TMR0 register has overflowed (must be cleared in software)
    0 = TMR0 register did not overflow
    bit 1 INTF: RB0/INT External Interrupt Flag bit
    1 = The RB0/INT external interrupt occurred (must be cleared in software)
    0 = The RB0/INT external interrupt did not occur
    bit 0 RBIF: PORTB Change Interrupt Flag bit
    1 = When at least one of the PORTB general purpose I/O pins changed state (must be cleared in software)
    0 = None of the PORTB general purpose I/O pins have changed state
    Note 1: The appropriate bits in the IOCB register must also be set.
    Jun 2007
    Germany
    Oh i get it ;-)
    Only to set
    IOCB.7 = 1
    IOCB.6 = 1
    and it works !
    Thanks a lot
    with
    INTCON.7 = 0 in the main loop the interrupt is repeating 2 times. Pushed 1x and release 1x.
    With the IOCB only on change till the interrupt is executed.
    Oh, Very good!
    I didn't even notice the 913 had individual enable bits for the RBC interrupts.
    Sitting here with the datasheet too going, "It should work!" Doh!, wrong.
    Nice job.
    Thanks Bruce,
    Let me know when you get the CAN module working. <hr>
    Oh, and Robson,
    I was just chit-chating with Bruce before.
    INTCON.7 = 0 should not be in your program.
    Sorry for the confusion.
