Hi owali,
Welcome to the PICBASIC forum. You are on the right track, starting with a simple, program and circuit.
Oscillator=RC
Is generally used for the Resistor/Capacitor Oscillator not for a 20 MHz ceramic resonator.
-Adam-
Hi owali,
Oscillator=RC
-Adam-
Hi owali,
I could not find any reference to the PIC16F83A.
If you PIC can allows a 20Mhz resonator try:
DEFINE OSC 20
Also, the PBP manual says;
The oscillator defaults to XT on most devices.
This is the setting for the default 4MHz oscillator.
If a faster oscillator is used, this setting must be changed to HS.
-Adam-
Hi owali,
See Melanie’s extremely helpful post:
Presetting Configuration Fuses (PIC Defines) into your Program
Are you using PBP or PBC compiler?
-Adam-
