measure the xtal
Results 1 to 12 of 12
    Hi, Savnik
    An easy solution is to use an external RC circuit and use ... RCTime ( 16 Bits result ...) !!!
    calibrate RCTime ( low drift components !!! ) with a Known Freq XTal ...
    With another XTal The Result will be proportionnal to the XTal Freq change ...
    That's all, Folks !!!
    Won't the output from RCTime be a logarithmic response, in other highly non-linear? You'd probably have to do some serious math to get accurate results.
    Hi, Skimask
    you Just forgot The XTal range won't be from zero to infinite ... 1 to 20 ... may be.
    But, as always, I'm not so sure of what our friend intends to do ...
    Jun 2006
    I have done a frequency meter with prescaler (256) from 10-1400Mhz.
    I did it with pbp(tmr0) and asm.
    But now i want to make a frequency meter from 0 -10 Mhz with only pbp.
    Quote Originally Posted by savnik View Post
    Well, I gave you an idea that I thought was fairly good...whether you use it or not is up to you...either run with it or don't...
    Wink Problem explained = half solved ...
    Hi, Skimask
    I'm out on this one ...
    I thought at first Savnik wanted to build some kind of XTal "identifying Gizmo" ...
    For a Freq meter, I never found simpler than The µChip AN 50 Mhz freq meter :
    1 16F84
    1 74HC 132
    1 Input Fet
    1 LCD ...
    rather simple. But works fine. ASM program ...of course.
    links to clones :
    http://www.sixca.com/eng/articles/fc50/index.html
    Note their PCB is to re-design ... too close layers in the P.A. section ... I couldn't measure over 7-8 MhZ with their design.
    Got 50+ Mhz with a re-design of PCB ...
    and :
    http://www.sprut.de/electronic/pic/p...quenz/freq.htm
    Also simplified ...
    http://l.lefebvre.free.fr/freq/freq_01.html
    And the last one :
    http://www.artra-qrp.com/fp50/fp50.html
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 16:04
  2. Xtal speed vs PIC power
    Last Post: - 4th January 2010, 20:55
  3. Using CCP1 and CCP2 to measure instant fuel consumption
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 20th September 2008, 16:50
  4. How can I measure Duty cycle ?
    By MaxiBoost in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 16:02
  5. using internal xtal
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2005, 17:25
