PIC network over AC 220V
Results 1 to 10 of 10
    Default You are the best Phoenix ...
    Yes, your idea with TDA kicked me to the right direction ))))
    I am thinking now about the security of this solution, some kind of encryption or authentication, but anyway your idea was the best !!!
    May 2007
    Republic Serbia
    Smile my pleasure
    Quote Originally Posted by rgregor View Post
    If you need more ideas write me here or on my Email.
    I have one question!
    Do you have some time problem like address 001F error write on 16F84A!
    Today I read this first time in my life (37 year old) and I can read PIC
    and I can't erase or write them !!!
    PIC is not code protest !!!
    I don't know hove to fix this problem - need some idea !!!
    Best regards
    I would bet of a poor JDM type programmer and IC-Prog? Case not, just tell us which one you're using
    How do you program it? in the socket or ICSP?
    May 2007
    Republic Serbia
    Lightbulb replay
    I programming with ALL programmer ( not JDM ) and I was probe with ICSP to
    but last night I was erase all in 16F84A @ 4 MHz , and after reading I was see
    that at location 029F still have writen some code !!!
    I was replaced that pic with next and board work correct but I want to find
    what was hapend with this firs.
    Its programmed only 3 times (program memory).Data memory is clear - not usage data location - eeprom inside.
    Sorry for may bad english !!!
    Regards by phoenix
  1. how to connect ac sensor to PIC ?
    By iugmoh in forum Schematics
    Last Post: - 1st June 2008, 18:35
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. How to make your own PIC network
    By mister_e in forum Code Examples
    Last Post: - 27th February 2007, 22:51
  4. Adding a pic in I2C network....
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2005, 12:07
