Serial cable problems
Results 1 to 6 of 6
    May 2007
    Unhappy
    So, what you're saying is...you have nothing. Even though I don't own any of the hardware in question here, I found everything you probably need to know with a Google search.
    How much other programming with the PIC have you done so far? Which PIC are you using? What does you circuit look like with the PIC hooked up? Post the troubled code you are using...
    Im not using a PIC but an ATMEL mega16. But after I was reading the thread you posted i thought, that there must be someone in this forum that could help med connect my MCU with my phone. Im sorre if its the wrong forum.
    The MEGA16 chip is mounted on a STK500 kit, that have an RS232 I/O. I just need some kind of connection circuit between the comport on the STK500 and my original nokia DLR-3P cable.
    Is it possible, or do i need to make a cable from atrox.at?
    Sorry im a bit difficult to understand, but english is not my best language
    Quote Originally Posted by akilleuz View Post
    PicBasicPro doesn't compile code for Atmel MCU's.
    Not hard to understand (ok, maybe just a little)
  1. USB and serial cable connection(s)
    By ardhuru in forum Schematics
    Last Post: - 18th August 2008, 16:26
  2. PIC to PIC Serial data using Cat5 cable
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 03:42
  3. Serial Communication Problems (Strange!!)
    By Armando Herjim in forum Serial
    Last Post: - 20th June 2006, 23:46
  4. serial communication problems
    By bronorisp in forum mel PIC BASIC Pro
    Last Post: - 21st January 2005, 00:50
  5. Serial comm Problems
    By Fossil in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 03:29
