output's on as power is supplied
Results 1 to 13 of 13
    And again...b3 does not make any sense.
    When you define a variable, you define it as a type; a bit, a byte, a word, a bucket, a scoop of ice cream, a car, whatever...
    What exactly is a b3?
    B3 is defined in the "bs2defs.bas" INCLUDE file.
    It's an alias to W1.HIGHBYTE. W1 is also defined there as a WORD.
    Ahhh...that covers why it compiles with errors...
    2nd round
    IT COMPILE WITHOUT ERROR, IT'S DEFINED IN THE BS2DEFS.BAS file.
    unless you removed the INLCUDE "BS2DEFS.BAS" linet, IT WILL COMPILE WITHOUT ERROR.
    Once again ?
  1. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. Outputs high to power
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 19:29
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
  5. Power up problem
    By Ken McDonald in forum General
    Last Post: - 28th December 2004, 18:06
