IR software & hardware basics
Results 1 to 14 of 14
    SWITZERLAND (french speaking)
    Thanks a lot skimask,
    I'm gonna try an IR module.
    I've seen on rentron's web site that he used a NAND.
    Going to check this out - didn't read this carefully enough.
    May I ask you over which distance you got good & reliable results?
    Dave, just saw your post. Yup, going for a module!!
    Roger
    Dec 2005
    The receiver filters out ambient IR from sunlight, incandescent lights, fluorescent lights, etc. If it's narrow-band it only reacts to IR that is modulated at the carrier frequency it is designed for. It's also designed for a specific wavelength (your phototransistor is 900nM while most consumer IR uses 940nM). Your test setup is about as bad as one could imagine.
    A few years back I designed a CF card that fit an iPAQ and acted as a Consumer IR transmitter. With a single IR emitter and 3.3V it regularly got 30 meters range but that's about 5 times what I expected.
    Thanks a lot skimask, I'm gonna try an IR module.
    I've seen on rentron's web site that he used a NAND. Going to check this out - didn't read this carefully enough. May I ask you over which distance you got good & reliable results? Dave, just saw your post. Yup, going for a module!!
    Maybe I did use a NAND gate, don't remember at the moment...
    Some people use gates, some people actually switch the PICs internal timer that generates the 38Khz on and off really fast.
    And there's those which build their own serial IR routine... or modify the existing SEROUT/DEBUG etc etc. To me the AND gate is sure an option... but not needed when you can do everything in software... with some head-banging for sure.
    I remind that Darrel already did something like that here modifying the SERIAL macro in the PBP files, i will try to find it.
    well, it was for XOUT, but there's an interesting concept.
    http://www.picbasic.co.uk/forum/show...ignal+stronger
  1. Benefits of hardware usart over software?
    By sccoupe in forum Serial
    Last Post: - 19th March 2009, 02:16
  2. Hardware or Software
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 00:22
  3. hardware counting while software runs
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 04:26
  4. Programming software for PicAll Hardware
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 16th July 2006, 09:15
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 18:12
