PIC16F88 senior design
Results 1 to 40 of 72
    Whoa...ease up there Sparky...
    Ya gotta figure...somebody comes on-line, asking questions which should be obvious 'cause they're in the manul, says there is no manual, is doing some sort of senior project at a University... Again, it all sounds fishy to me...but that's not the point...
    The posts I've given here are MINE...nobody's else, just mine and only mine. Don't take my 'opinions' as the rules around here. There may be people around here that are a lot more giving than I am, good for them. I look for a bit of 'one hand washes the other' type thing. You ask a question, I give you the answer, hopefully that answer can lead you to other answers, so you don't have to ask as many questions.
    As a 'for instance'...you stated in post #4 that the 16F88 doesn't have an internal oscillating crystal. Well, you would've known that the 16F88 had it's own internal oscillator block that can run at a number of speeds if you'd have read the datasheet, and not even read it, but at least skimmed over it fairly well.
    That's the kind of thing I'm talking about...the blatently obvious question that could've been avoided by the least bit of 'research'. And there ya go...
    So...after you have taken my advice written in post #3 into account and have made some changes to your code. Recompile the code, work the hardware, try it out, and let us know what's up...
    T.Jackson's Avatar
    T.Jackson Guest
    I'm convinced that someone comes to this forum looking to strike up arguments.
    Cool
    Yep...that's my only function...
    Actually, here's my only function:
    nuffsaid var bit : nuffsaid = 1
    Argument var bit : Argument = 0
    blatentlyobvious var bit : blatentlyobvious = 0
    argument = 1
    if argument then
    gosub skimask
    skimask:
    blatentlyobvious = nuffsaid
    Any questions?
    Thumbs up
    I think sometimes you might need to use WORD size VAR.
    Check the DATA sheet, bit is not big enough.
    How 'bout this:
    nuffsaid var bit : nuffsaid = 1 : Argument var bit : Argument = 0
    blatentlyobvious var signed_quad_double_float[10 ^ 100]
    argument = 1 : if argument then gosub skimask
    skimask:
    blatentlyobvious = 1 / 0
    Now then...how 'bout that new, improved code AlaskanEE?
    Mar 2005
    Iowa, USA
    Looks to me like an improper assignment of a variable. Check out page 21 section 4.3 of the little green book and let us know what you find out.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Quote Originally Posted by rhino View Post
    Oh, that variable type is in my 'PBP' wish list, and the number of elements in that array are in my 'PIC' wish list.
    Dec 2005
    Some forums allow members to create an Ignore List so they don't have to read posts from unhelpful misfits.
    A forum such as this one, yes...
    ...and I would use it...but I don't, and some of the comments, whether pointed at me (or anybody else) directly or indirectly... they amuse me...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    What astonishes me the most is how tolerant the admins on this forum are.
    I personally wouldn't put up with some of it.
    Admins don't always have time to read all posts on all threads!
    Let's be nice people - or let me rephrase that - Let's be nice on this forum....
    I know it's tempting to reply to almost every newbie "Read the Manual or Read the Datasheet", I've done it myself to folks - and not just once or twice. It's frustraiting to read some of the posts, especially when there's a 14-page list of what they have to do/achieve and it's coupled with a request for schematics/code/help/complete ready-canned solution for free and the deadline is today lunchtime and they've still got to play a soccer match in the interim - oh, and by the way they haven't got a clue about electronics/programming, they're really a philosophy student that's been landed with the task.
    OK, we've heard it all before! Sometimes it's better not to answer, and people might get the message that they are expected to make some effort themselves too. And if they're really that clueless then a Landscape Gardening project (growing a dwarf Marijuana or similar) is probably a better student option.
    With all the spam and viri floating around these days, I'm surprised you have any time to read any of the posts...
    Whoa! Where'd that come from?
    Apr 2007
    I thought I might have burnt out my PIC so I started trying very basic commands to test it out. Just output a voltage high on one pin when there's a voltage high on the input pin. This is the code I used:
    DEFINE OSC 8
    TRISA.1 = 1
    TRISA.2 = 0
    LOOP:
    IF PORTA.1 = 1 THEN HIGH PORTA.2
    GOTO LOOP
    I used a VDD of 5V and got an output of 5V at A.2 but sometimes it will suddenly drop to 0 volts without me adjusting anything. I remove the pic from the circuit and then put it straight back in and the output is at 5V again. Sometimes the voltage stays for a while sometimes it goes away rapidly. Does it sound like my PIC might be faulty? or is there a problem in my code. Also if the PIC is outputing a high and I remove the high input I would expect the output to drop as well, but it doesn't. Do I need to include a second IF, THEN statement to achieve this result?
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. pic16f88 & voltage
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 09:14
  3. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 16:09
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
