datalogging from pic16f877a to usb-stick
Results 1 to 10 of 10
    Apr 2007
    Default about dos on chip
    I read the datasheet for the dosonchip, but how do you read and write data from the sd chip\?
    Do you need to tell which memory adress you want to write or read or is this done automatically with hserin hserout?
    i use pic basic pro
    Quote Originally Posted by arie View Post
    i use pic basic pro
    I use PicBasicPro too...imagine that...
    No, you don't tell which memory address to read/write from.
    This chip is a DOS on CHIP. Disk Operating System On A Chip.
    It's an interface chip, a 'relatively' seamless interface chip.
    With it, you can treat the SD card just like you would treat a floppy disk (or maybe a small hard drive) from a DOS command prompt. Ok, it's a bit more complicated than that, but not by much.
    If this is your first project...whew...don't get me started...
    If it actually is your first project...I'd back up, WAY up, and make an LED blink first.
    If it isn't your first time around the block, then it really shouldn't be that hard, unless you haven't really read the datasheet (which explains everything you really need to know as long as you really READ it), or maybe you haven't messed with the serial port before, in which case, I say again, You'd better back WAY up, and make something simple first, like PC to PIC communications.
    Apr 2007
    I did make some pic projects by myself, but this is the first time I use serial communications. Hserin and hserout works perfectly with pic to pc. But i can't get serin and serin2 etc to work properly. Could it be that I use a bootloader so there must be an extra code inserted in pic basic pro just like lcd and bootloader
    Well then, let's see some code. That's what we're here for...
    Apr 2007
    I tried it without an bootloader and programmed th pic16F877A with an usb programmer this works ok! Does anybody know how to get the stuff working with a bootloader I use the bloader from sparkfun
    this is the code that works only if you not program it with a bootloader
    FLAGS=0
    DEFINE LOADER_USED 1
    Define __16F877A 1
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    define CHAR_PACING 1000
    Include "modedefs.bas"
    LCDOUT $FE, 1
    TRISA = %00000000 'porta = output'
    TRISB = %00000000 'portb = output'
    TRISC = %10000000 'portc.7 = input'
    rx var PORTC.7
    tx var PORTC.6
    but0 var portc.0
    but1 var portc.1
    but2 var portc.2
    but3 var portc.3
    led0 var portb.0
    led1 var portb.1
    led2 var portb.2
    led3 var portb.3
    led4 var portb.4
    led5 var portb.5
    led6 var portb.6
    led7 var portb.7
    backl var porte.0
    high backl
    serout2 portc.6, 813, ["hello world", 10, 13]
    I really appreciate it that everybody is so helpfull cause the simple things are sometimes though to crack! When I'll receive my dosonchip and gps receiver I'm going to test it a lot. Now I'm just doing research to everything I need to use in my project.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. Replies: 0
    Last Post: - 6th March 2009, 08:52
  4. Usb X Pic16f877a
    By LLEEDD in forum USB
    Last Post: - 30th December 2007, 22:52
  5. USB memory stick
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 12th July 2005, 21:57
