Microcode v3.0
Results 1 to 14 of 14
Thread: Microcode v3.0
    Nestyplus's Avatar
    Nestyplus Guest
    Default Microcode v3.0
    Hi Guys,
    Anybody knows on what's new with the latest version 3.0 of Microcode Plus?
    I just noticed it on the site of melabs.
    The new version is compatible with Windows Vista.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    SWITZERLAND (french speaking)
    Default any history?
    I assume some other enhancements must habe been included, no?
    I could'nt find a detailed version history on MECANIQUE's site.
    Is there any?
    Roger
    I'm not sure just what has been changed other than being Vista compatible, but I'm sure once they find time, they'll update the history page.
    -Bruce
    tech at rentron.com
    Nestyplus's Avatar
    Nestyplus Guest
    Default Microcode ver 3.0 online update
    Bruce,
    Thank you for the swift reply. I tried to click the Online Updates when inside the Microcode environment and it shows that it is connecting with final comment at the right bottom bar 'No new updates'.
    I just don't understand it looks to me that their online update isn't really working. Have you tried it?
    Btw, I have the microcode plus 2.3.0.0 and I'd like to have it updated through its online update button.
    As far as I know only the free version is out. Im guessing a little more time
    & preparation goes into the paid version before it gets released or announced.
    Patience...;o}
    -Bruce
    tech at rentron.com
    Nestyplus's Avatar
    Nestyplus Guest
    Smile Microcode ver 3.0 online update
    Patience...;o}
    Bruce, thanks I believe you're in close contact with them since you market their product. Don't forget to send a note in this forum when the paid version is ready for released through online.
    You should be able to update MCS+ using the online update now.
    -Bruce
    tech at rentron.com
    AND those having the original MicroCodeStudio PLUS on a black CD...don't forget to read the whole thing about the update before doing it...
    Default How to configure fuses...
    I've bought the PICKit2 from MICROCHIP and received also a 16F690. Well, since it's here, let's try it
    I'm using MicroCodeStudio v3 and this chip is in the device list.
    After looking at the chip's bibel and the P16F690.INC file from MPLABS, I established the fuse list in the editor.
    Unfortunately, I always get errors "undefined symbol xxx" when compiling where xxx are four fuse settings appearently not recognised by MCS.
    This is probably a syntax error on my side but I don't know where I can find this information.
    Does anyone know?
    NB: can't get any answer from MECANIQUE...
    Roger
    Post your config settings. I use this one a lot. It's the controller for our
    new serial LED display module.
    -Bruce
    tech at rentron.com
    Default 16F690 fuse list
    Hello Bruce,
    Here is my fuse list. I could correct two fuses since my last post.
    There are only two fuses not beeing compiled (bolded) without error in MCS at this moment.
    ' Fuses
    @ DEVICE PIC16F690,FCMEN_OFF
    @ DEVICE PIC16F690,IESO_OFF
    '@ DEVICE PIC16F690,BOR_OFF
    @ DEVICE PIC16F690,CPD_OFF
    '@ DEVICE PIC16F690,CP_OFF
    @ DEVICE PIC16F690,MCLR_OFF
    @ DEVICE PIC16F690,PWRT_OFF
    @ DEVICE PIC16F690,WDT_OFF
    @ DEVICE PIC16F690,INTRC_OSC_NOCLKOUT
    If possible, can you explain how anyone can do this by himself?
    Roger
    Default last ones found...
    Bruce,
    I just found the syntax for the last two fuses.
    @ DEVICE PIC16F690,BOD_OFF (instead of BOR_OFF)
    @ DEVICE PIC16F690,PROTECT_OFF (instead of CP_OFF)
    Still don't know how to find this out without chance...
    Roger
    Hi flotulopex,
    The only way to know which config fuse options you can use the the PM
    asembler & the @ DEVICE options is to look in the PBP header file.
    They don't always follow the Microchip device header file naming conventions,
    so it's always a good idea to look at the PBP device header file 1st to know
    which options are available.
    -Bruce
    tech at rentron.com
  1. Replies: 3
    Last Post: - 1st July 2008, 21:07
  2. Code Folding - Microcode Studio Wish
    By Rob in forum PBP Wish List
    Last Post: - 6th December 2007, 09:11
  3. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  4. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 09:28
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 00:29
