Differential Drive Programming
Results 1 to 15 of 15
    Feb 2005
    Kolkata-India
    Default I do not fit here
    Hi All,
    I really do not fit in this thread cause I have no experience in robotics but perhaps can share some view.
    Creating a complementary output just by inverting the PWM out pin and feeding one part.
    1. If you are driving a H-bridge then applying a 50% duty doesn't move motor.
    2. Anything less than 50% or greater than 50% would result in motion in either directions. Speed prportional to duty cycle.
    3. Shutting down both half causes braking.
    Darrel has done a Multiple Soft PWM stuff. Find it here http://www.pbpgroup.com/modules/wfse...p?articleid=12 . It can be easily adopted to get complimentary outputs. Also possible to include dead times.
    Only the PWM freq cannot be high (if you have other tasks to do in between, you run out of cycles). However for a two channel version it should work with some audible noise from the motor. Don't blame me if you burn one.
    Sougata
    Quote Originally Posted by sougata View Post
    Hi All,
    Exactly...software pwm, run as many channels as you have cpu time to handle, at any rate.
    Complementary PWM - exactly! Easy to do with software PWM, one bit mirrors the other...
    Very easily done. Not hard to grasp...
    Apr 2006
    That was just superb!
    I got it now how to deal with Software PWMs. Thanks a lot all of u!
    Now can anybody tell me that how would i determine that what frequency do i need to supply in order to run my motor correctly. I mean what is the effect of frequency on motor?
    e.g:
    if i apply a pWM of freq 100Hz to a motor
    and then apply a PWM of freq 1000Hz to the same motor.
    What will be the difference between the two?
    LETS MOVE TOWARDS SOMETHING PRACTICAL---
    Quote Originally Posted by shaiqbashir View Post
    e.g:
    900 Hz.....
    Apr 2006
    haha Skimask!
    that was superb Intelligence.
    WEll! Im asking about the effect actually.
    I want to know what is the effect of frequency over the running of a DC motor.
    Does increase/decrease in frequency affects the Running of the motor?
    I'm certainely not a motor expert, but i think some motor may work, somes not... or simply don't like it... or not.
    mmm.... any datasheet or info on your motor?
    Too low... maybe the motor could shake.. to high... maybe you will hear it.
    Who's the motor expert here?
    Wink Hardware defining ...
    Hi, Shahiqbashir
    I realized some years ago such a thing for my large model boats ...
    But I used TWO PWM outputs to get rid of the PWM soft drive ( other more useful stuff to do during this time ) ... so, it was aboard a 16F876.
    With all the "whistles and bells" ... it took 3783 memory words.
    That's to tell you a 16F84 will be really, really small for such a purpose ( PbP programmed overall !!! )
    These days, the 18F1230/1330 offer you such features aboard a 18 pins package. ...
    Worth some reflexion ???
    PS: other possible solution : 1 16F84 cares of the input signals ... and drives 2 16F84s which drive the motors ...
    Wink PWM Freq.
    Hi, Steve
    For such model motors it's commonly admitted ~ 3-4000 Hz for ferrite magnets ( to let them some life ...) , and what you want for rare earth magnets.
    Note at higher frequencies, it will be difficult to drive the Mosfets directly from the PIC, due to their High input capacitance ...TC 442x drivers are then to be used.
    soooo, in all cases, you'll have a sweet music for free...
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. MPASM Path & File Name Length Limtation
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 16:48
  4. Telescope drive motors that don't...
    By Dodgy Geezer in forum General
    Last Post: - 12th April 2008, 03:05
  5. Seeking Help With Programming PIC16F688
    By gzayzay in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 04:32
