Using DS18S20 vs DS1820 with 4x7 LED Displays
Results 1 to 15 of 15
    Jan 2006
    Istanbul
    Default Using DS18S20 vs DS1820 with 4x7 LED Displays
    Hi there,
    Since DS1820 temp chips are replaced by DS18S20, we get a slower convertion time.
    500ms vs. 750ms.
    When using 18S20 (or 18B20), I get a blank on LED display while the convertion is in progress while I get no blank display using 1820.
    Any idea how to overcome this issue?
    Been awhile, but if I remember correctly, you can send a "Start Conversion", then just check the busy flag on each loop. When it's done, goto a subroutine to get the result.
    Most examples that I've seen just sit in a WHILE/WEND or similar loop waiting for the busy flag without doing anything else. 3/4 of a second is a long time.
    Jun 2005
    Wisconsin
    Quote Originally Posted by Darrel Taylor
    I use a timer to send the start conversion every second. Then I check the flag via a loop, based on the flags status I either retrieve the info and update my display or continue on with other things. While/Wend wastes too much time for me.
    Jan 2006
    Istanbul
    Thanks for the info DT.
    Let me work on that bit.
    sayzer,
    Are you using Bruce's code with the SLED4C, or independant 4 digit seven segment displays.
    I was just thinking that if it's the SLED4C, it might be a different problem. Don't know what, but it wouldn't blank no matter how long it took for the conversion.
    Just curious.
    Jan 2006
    Istanbul
    ...Are you using Bruce's code with the SLED4C, or independant 4 digit seven segment displays...
    Thanks DT.
    I am using Bruce's code with independent 4-digit Seven segment displays (two displays; 8 digit).
    Jan 2006
    Istanbul
    Ok. I got it working with no delay (for DS18B20).
    Meanwhile, I encountered something insteresting.
    None of the DS1820 codes on this forum, and on other sites, has a routine for negative temps.
    Isn't it interesting? All of the codes read the bit that indicates "negative" but that is it. With these codes, when the temp is negative the actual temp value becomes incorrect.
    DT, you have a post here : http://www.picbasic.co.uk/forum/show...ghlight=DS1820
    But it did not work for me. I did not understand how a negative result of an equation would work => TempC = 0 - TempC
    Also, here is the table from DataSheet.
    <img src="http://img10.picsplace.to/18/ds1820.GIF" alt="Image Hosting by PicsPlace.to" >
    Here is the most popular code for DS1820
        owout DQ, 1,[$CC, $44]
        owin  DQ, 4,[var1]
        if var1 = 0 then            'Being busy issue.
            owout DQ, 1,[$cc, $BE]
            owin  DQ, 0,[tempc.lowbyte, tempc.highbyte, skip 4, var1,var2]
        negsign=tempc.15
        TempC = (TempC>>1)*10 + (TempC.0 * 5)
    For DS18B20, negative temp value is no problem with Bruce's code.
    Jun 2005
    Wisconsin
    Darrel made an include that does temp conversion, and it goes into negative temperatures.
    http://www.pbpgroup.com/modules/wfse...p?articleid=18
    Give this a try.
    Sayzer,
    I'm confused. Does that mean Bruce's code fixed your problem? Or, do you still need help?
    And, you're asking about the DS18B20, but the table is for a DS1820
    Jan 2006
    Istanbul
    Sorry for confusion.
    I have already fixed my problem with DS18B20. I have no problem. I get nice negative value reading, too. Everything is perfect.
    But,
    For DS1820, how do we read negative values? When the temp gets below zero, how do we read it? I could not find a PBP sample code for negative part. I have about 50pcs DS1820 left in hand and have a chance of getting rid of them if I can read negative values.
    The table is for DS1820.
    Give this a try...
    Sign  VAR  BIT
    TempC VAR  WORD
    ; read DS1820 here
    Sign = TempC.15
    TempC = ABS(TempC)
    TempC =(TempC>>1)*10 + (TempC.0 * 5)
    IF Sign then LCDOUT "-"
    LCDOUT dec (TempC/10),".",dec TempC//10
    Jan 2006
    Istanbul
    It is finally working now for the negative values.
    I did not have this TempC = ABS(TempC) before TempC =(TempC>>1)*10 + (TempC.0 * 5)
    But, now I get correct values.
    Thanks a lot Darrel.
    Regards.
    You're Hoşgeldiniz
    Jan 2006
    Istanbul
    Default Lost in Translation!
    Very nice of you "trying" to say that Darrel.
    I see what you wanted to say, thank you.
    But the meaning is a typical "lost in translation".
    "Don't mention it" in Turkish = "You are welcome" in English
    "You are welcome" in English = "Well Arrived" or "Welcome to a 'place'..."
    Here are some funny ones:
    Italian:
    "Ladies, leave your clothes here and spend the afternoon having a good time."
    Japanese:
    "Special cocktails for the ladies with nuts"
    Swedish:
    "Fur coats made for ladies from their own skin"
    "Our wines leave you nothing to hope for"
    French:
    Colgate introduced a toothpaste in France called Cue, the name of a notorious porno mag.
    French:
    "Please avoid coca watering, cream cleaning, wet towels wrapping, and ironing drying."
    And a funny one in German:
    "It is strictly forbidden on our black forest camping site that people of different sex, for instance, men and women, live together in one tent unless they are married with each other for that purpose."
    Have more here:
    http://www.ojohaven.com/fun/translation.funnies.html
    Talking
    Ha Ha,
    Well, at least I didn't end up calling you a bad name or something.
    Darn those on-line translators.
    The thoughts still there though...
    You're welcome.
    P.S. Funny Link.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  5. LCD will not start
