Using DS18S20 vs DS1820 with 4x7 LED Displays
Results 1 to 15 of 15
    Jan 2006
    Istanbul
    Quote Originally Posted by Darrel Taylor
    ...Are you using Bruce's code with the SLED4C, or independant 4 digit seven segment displays...
    Thanks DT.
    I am using Bruce's code with independent 4-digit Seven segment displays (two displays; 8 digit).
    Jan 2006
    Istanbul
    Ok. I got it working with no delay (for DS18B20).
    Thanks for the info DT.
    Meanwhile, I encountered something insteresting.
    None of the DS1820 codes on this forum, and on other sites, has a routine for negative temps.
    Isn't it interesting? All of the codes read the bit that indicates "negative" but that is it. With these codes, when the temp is negative the actual temp value becomes incorrect.
    DT, you have a post here : http://www.picbasic.co.uk/forum/show...ghlight=DS1820
    But it did not work for me. I did not understand how a negative result of an equation would work => TempC = 0 - TempC
    Also, here is the table from DataSheet.
    <img src="http://img10.picsplace.to/18/ds1820.GIF" alt="Image Hosting by PicsPlace.to" >
    Here is the most popular code for DS1820
        owout DQ, 1,[$CC, $44]
        owin  DQ, 4,[var1]
        if var1 = 0 then            'Being busy issue.
            owout DQ, 1,[$cc, $BE]
            owin  DQ, 0,[tempc.lowbyte, tempc.highbyte, skip 4, var1,var2]
        negsign=tempc.15
        TempC = (TempC>>1)*10 + (TempC.0 * 5)
    For DS18B20, negative temp value is no problem with Bruce's code.
    Jun 2005
    Wisconsin
    Darrel made an include that does temp conversion, and it goes into negative temperatures.
    http://www.pbpgroup.com/modules/wfse...p?articleid=18
    Give this a try.
    Sayzer,
    I'm confused. Does that mean Bruce's code fixed your problem? Or, do you still need help?
    And, you're asking about the DS18B20, but the table is for a DS1820
    Jan 2006
    Istanbul
    Sorry for confusion.
    I have already fixed my problem with DS18B20. I have no problem. I get nice negative value reading, too. Everything is perfect.
    But,
    For DS1820, how do we read negative values? When the temp gets below zero, how do we read it? I could not find a PBP sample code for negative part. I have about 50pcs DS1820 left in hand and have a chance of getting rid of them if I can read negative values.
    The table is for DS1820.
    Give this a try...
    Sign  VAR  BIT
    TempC VAR  WORD
    ; read DS1820 here
    Sign = TempC.15
    TempC = ABS(TempC)
    TempC =(TempC>>1)*10 + (TempC.0 * 5)
    IF Sign then LCDOUT "-"
    LCDOUT dec (TempC/10),".",dec TempC//10
    Jan 2006
    Istanbul
    It is finally working now for the negative values.
    I did not have this TempC = ABS(TempC) before TempC =(TempC>>1)*10 + (TempC.0 * 5)
    But, now I get correct values.
    Thanks a lot Darrel.
    Regards.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  5. LCD will not start
