SMS control for Relays
Results 1 to 16 of 16
    Sep 2003
    INDIA
    Default SMS control for Relays
    Hello all,
    I successfully tried out this code to control a bank of eight relays using SMS over GSM network. Just thought of sharing it with all so that others could use it.
    Hardware setup:
    Processor : 16F72
    PortB : Connected to relays via ULN2803 driver IC.
    PortA: 16x2 LCD
    Modem : SIMCOM GSM/GPRS Tri Modem
    Consideration : The Modem is configured @ 9600 baud. Pin #7 and #8 are shorted at the 9 pin D connector on the Modem Side. AT+CMGF=Text. ATE0 (no echo). The code shows control of only 4 relays but you can add all eight to it. This code can be optimised for code space , but can be used as a starting point.
    regards
    Jan 2006
    Default Sms
    Nice work charudatt,
    Would it be possible deploying this stuff of yours to PIC16F628A using onboard crystal.
    Can you give further explanations on the DEBUG statements? I'm curious about functionalities of those lines especially the extraction of SMS from a cell phone.
    Is there a way of eliminating the MODEM? What models of cellphones should i use?
    Sep 2003
    INDIA
    Default Thank you.
    Emavil,
    1. I believe you can do it on the F628A.
    2. Simply go through the Compiler Manual and you shall know about the Debug statement. I used the debug statement to save on code space.
    3. Modem ? No I am using a Industrial type Mobile which has a Serial Port control and accepts AT commands. Type Simmcom. Yes , I you see this month's EPE magazine , you will come across a similar project using the Nokia phones.
    regards
    Jan 2006
    Thanks for that.
    I'm not refering to the DEBUG command, instead, those AT commands. Can you share to me the basic principles (background) on how to extracting SMS messages from a cellphone. I find it hard interpreting your code especially those AT commands. I know that there are special registers in the cellphones to deal with. What interest me most is the theory behind the extraction of these messages.
    Quote Originally Posted by emavil View Post
    Thanks for that.
    Last edited by skimask; - 22nd March 2007 at 01:17. Reason: Abosulutely fine answer and hints removed due to possible legal issues...
    Default sms
    Two questions
    DEBUGIN [WAIT("+CMGR:"), SKIP 53 , DEC MYDATA]
    if i understand your code correct you are expecting a byte value in MYDATA what will happen if this is bigger than a byte
    2nd question
    I am using a MC55 modem from siemens
    +CMGR: "REC UNREAD","+27829554322",,"08/04/19,13:08:34+08"
    test
    if i only want to extract the cell number will this be the correct command, as what do i need to conf cellNumber and what will happen to the rest of the serial string comming in
    DEBUGIN [WAIT("+CMGR:"), SKIP 16 , cellNumber]
    zouzanda's Avatar
    zouzanda Guest
    hello all if my modem is nokia phone what can i change to make it work?
    Apr 2009
    anybody share Schematic diagram ??? i really wana use it..
    Quote Originally Posted by charudatt View Post
    Hello all,
    Hardware setup:
    Processor : 16F72
    PortA: 16x2 LCD
    regards
    May 2008
    Italy
    Welcome to the forum. You can download it @ http://techni.caliti.es/blog/2008/12...ontroller.html
    Al.
    Sep 2003
    INDIA
    Hey Good compilation.
    regards
    Charudatt
    Apr 2009
    Quote Originally Posted by aratti View Post
    Al.
    Dear, upper attached codes for PIC16F72 and schematic for PIC16F873 is that ok?
    please let me know..
    May 2008
    Italy
    If you use the downloaded schematic you must also use the downloaded software (which is for pic16F873)
    Al.
    Apr 2009
    Al.
    sir, actually i want to change something into codes therefore i am asking for its schematic..
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 22:19
  2. Replies: 11
    Last Post: - 19th August 2009, 16:23
  3. Siemens c55 sms control help please
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 20th August 2008, 02:13
  4. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 18:24
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
