PIC temperature, when is it too hot
Results 1 to 24 of 24
    Default Re: PIC temperature, when is it too hot
    and of I/O is 1V*110mA =110mW
    provided that the current is spread over a number of i/o pins and that no individual pin is overloaded
    I rechecked my work to be sure, this is my busiest 40-pin PIC that I mentioned previously:
    - 16 rotary encoders pins pulled HIGH,
    - 4 momentary switches pulled HIGH,
    - 2 ADC inputs,
    - 2 PWM:
    __- pin for LCD backlight, 3mA (2N2907)
    __- pin for LED strip, 0.0mA (IRFZ44N) - so low it doesn't even register on my ordinary multimeter.
    - USART TX and RX pins pulled HIGH,
    - remaining unused pins are output pulled LOW
    (waiting for new fuses to retest using my TES multimeter)
    Aug 2011
    - 2 ADC inputs,
    - 2 PWM:
    It's hard to see how that ends up sourcing 110mA out of the IO pins... I would have guessed less than half that.
    Yes, the voltage drop across the switch increases as the current goes up. That's why I was being conservative with the 1V voltage drop.
    But really, as long as the voltage drop isn't MORE than 1V it wouldn't matter (from a power dissipation standpoint) if the 110mA exits the device thru one pin or 25. Of course, you'll likely destroy the pin but it's still 110mW dissipated.
    Point is, 600mW isn't being dissipated in the PIC. Keep the current to within specification and you'll be fine. No heatsinks, fans or watercooling needed. If you think you need that (chip is burning hot) something is wrong.
    BTW: Am I the only one not being able to edit my posts? All I get is a blank "edit box" as if I was making a new post.
    EDIT: Hmmm, not this time, on this machine. Weird.
    What I was thinking... Henrik is right as all that current is flowing out of the PIC and not to ground.
    So indeed, the only power loss is the voltage drop on the output buffer times the specific pin current.
    Sorry about that, guess it was too late at night to post anything...!
    not anymore
    i cannot edit my posts either
    Maybe clearing cache, or a different browser resolves the problem?
    tried all that. problem still comes and goes, seemingly at random
    Then only boss can check that...
    It got me too... I really cannot understand what is going on.
    It showed me an empty text box. Was it the same with you too?
  1. max232epe gets hot , real hot
    By richard in forum Serial
    Last Post: - 11th November 2014, 09:47
  2. Very hot rectifier
    Last Post: - 1st July 2014, 21:27
  3. Measuring temperature with a PIC
    Last Post: - 18th June 2012, 01:54
  4. Hot Tub Temperature Probe
    By DavidK in forum Off Topic
    Last Post: - 22nd November 2008, 10:45
  5. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 13:51
