Who sees my stupid mistake?
Results 1 to 28 of 28
    Feb 2012
    Default Re: Who sees my stupid mistake?
    I set the config parameters in the programmer (as usual).
    The values you mentioned are the defaults in my programmer, except the HS mode, that I set manually.
    The point is that everything (almost) works.
    If I create a loop that does nothing else than: serout2 xxx, delay 1000, I get MIDI information every second.
    My main suspect is that the switch(es) are not read correctly in: if PORTB.x =1 then ...
    Is this the "read modify write" problem?
    (I have to look that up whenever I encounter weird problems)
    Quote Originally Posted by RuudNL View Post
    I set the config parameters in the programmer (as usual)...
    What if you set them in the program? Maybe something is wonky with your programmer config. (total wild guess, just eliminating stuff)
    ...If I create a loop that does nothing else than: serout2 xxx, delay 1000, I get MIDI information every second.
    Blinking a LED confirms if your timing is running at the speed you think it's running at.
    I usually go for LED 1/2 second OFF, 1/2 second ON, just to know my OSC is running as it's supposed to.
    EDIT: Hm, yeah, but you're getting a SEROUT every second already, so not sure what else to check.
    Feb 2012
    I never had problems setting the config parameters in the programmer, but I will try that anyway...
    I have a feeling that the problem is in the line:
      if PORTB.0 = 1 then   '<---- this line?
        Serout2 PORTB.7, 16384+12, [144, 44, 127]    ' Rewind
    The strange thing is that the switch status IS correctly read in this part:
    Debounce:
      Pause 20                                          ' ? shorter ?
      If (PORTB.0=1) or (PORTB.1=1) or (PORTB.2=1) or (PORTB.3=1) or (PORTB.4=1) then
        PORTB.6 = 1                                   ' ADDED TO CHECK!!
        goto Debounce                                ' Button still pressed?
        PORTB.6 = 0                                   ' ADDED TO CHECK!!
      Goto Progstart
    So PORTB.6 is high as long as a button is pressed.
    And a loop Serout xxx/ Pause 1000 spits out a burst of MIDI data every second, so it doesn't look it is a config problem.
    Instead of this
    try this
        High LED
        Pause 100
        Low LED    ' Rewind
    Set LED to a Port and see if it blinks.
    Feb 2012
    It doesn't. I tried already:
      If PORTB.0 = 1 then
        PORTB.6 = 1
        PORTB.6 = 0
        ' and loop...
    PORTB.6 never gets high!
    I can't wrap my head around it...
    In the past I've written considerably more complicated code, usually with success.
    I think I'll sleep on it and try again from scratch tomorrow!
    Thank you everyone for your thoughts!
    Then fried PIC maybe?
    Feb 2012
    I doubt it... It is a brandnew one!
    What I find extremely strange, is that it seems the status of PORTB.x is not read in:
    if PORTB.0 = 1 then
    But IS read in:
    Debounce:
      Goto Progstart
    If it was a faulty PIC, this wouldn't work in both cases.
  1. I don't understand my mistake
    By kik1kou in forum mel PIC BASIC Pro
    Last Post: - 31st January 2015, 13:56
  2. Stupid simple question.....
    By chien_fu in forum mel PIC BASIC
    Last Post: - 23rd February 2010, 14:21
  3. Stupid question about LCDOUT
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 7th October 2008, 22:37
  4. SERIN2 – SEROUT2 and Manchester mistake.
    By RCtech in forum Serial
    Last Post: - 4th September 2007, 23:55
  5. Stupid question
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 06:47
