18F26K80 Code Optimisation.
Results 1 to 8 of 8
    Aug 2011
    Default Re: 18F26K80 Code Optimisation.
    Try using a clock osc chip instead of a crystall or resonator.
    That's what I used (an external 20Mhz osc) and it worked for me.
    Of course, that doesn't mean it'll work for all chips.
    If you want to increase the speed switch to a chip that has the CAN controller builtin.
    That avoids all the SPI transfers to the external controller.
    Why use the 2515 at all when the K80 has CAN?
    Because I'm talking on three separate CAN buses.
    The K80 only has one internal CAN module.
  1. 18F26K80 Serial setting sanity check and 4xPLL.
    Last Post: - 20th August 2023, 16:05
  2. Replies: 0
    Last Post: - 9th September 2018, 01:43
  3. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 02:15
  4. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 20:44
  5. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 19:51
