Small pin-count device for generating output frequencies when triggered
Results 1 to 10 of 10
Threaded View
  1. #2
    Default Re: Small pin-count device for generating output frequencies when triggered
    Jim, I have attached a small program I worte a few years back for a 10F222 processor. It was for generating 2 different tones simulating a CW message for amatuer radio to be used for ID or Fox hunting purposes. It would key the radio push to talk circuit, wait 250 Milliseconds and then send the message. It would then go into a sort of sleep mode for about 6 minutes. During the sleep time it awakes approx. every 2.5 seconds and reads a port pin to see if is being commanded to transmit before the timeout period. Use it as a starting point for your project. I don't see why you couldn't use the A/D to set the tone frequency.
    EN82fn
  1. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 09:32
  2. Replies: 3
    Last Post: - 24th September 2010, 08:10
  3. How to know what pin triggered an interrupt?
    Last Post: - 13th October 2008, 08:29
  4. Turn on output pin
    Last Post: - 11th March 2007, 12:49
  5. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:19
