Displaying a percentage
Results 1 to 12 of 12
    Oct 2009
    Default Displaying a percentage
    I have a word variable that can hold a number from 0 to 4096. I want to display the value of that variable as a percentage on an LCD. EG when it's 4096 it's 100%, when 2048 it's 50% etc. but can't think how to do it. I know that simply dividing 4096 by 100 will give me the increment value for 1%, but can't seem to format it to work correctly. From a previous bit of code I came across this which is used in a menu option to set the value of CH1_Max between 0 and 4096 by using a word variable which has a value between 0 and 100
    CH1_Max = maxbright */ 10484
    Any pointers ?
    Default Re: Displaying a percentage
    Percent = Value ** 1600 is one option but you're pissing away a lot of resolution.
    Oct 2009
    Thanks Henrik,
    Is there a way to get better resolution ?
    Feb 2005
    brookfield, ct, usa
    X = 4096 * 100
    Percent = div32 value
    Lcdout (dec2 percent)
    To get .1% is easy, same aproach:
    Percent = Value ** 16000   ' Percent is now 0-1000
    LCDOUT $FE, 1, Percent / 10, ".", Percent // 10
    Since you've got slightly over 4000 counts the smallest unit is around 0.025% but I don't know if you need, or even want, the display to show that?
    Or you could do it this way as there is no need to do another math operation on the variable:
    LCDOUT $FE, 1, Percent / 10, ".", Percent DIG 0
    Just format the variable....
    EN82fn
    Oct 2009
    many thanks guys, I'll give it a go when I'm home from work
    Oct 2009
    pc1 = CH1_PWM ** 1600
    lcdout $FE,$80,"CH1"," ",dec PC1
    This works nicely, apart from one small issue, in that it won't display 100. It reached 99 and that's it !
    By resolution, I didn't realise that you were referring to the decimal resolution displayed, but was referring to the maths (I assume that whatever divisions were happening the increments for each 1% would be rounded down to an integer as PBP doesn't support FP maths).
    Is there a way where I can display 100 for 4095 steps ?
    Well, to be fair you said your value ranged from 0 to 4096, that's 4097 "steps" ;-)
    pc1 = CH1_PWM ** 1601
    There WILL be rounding (or truncating rather) issues, yes.
    pc1 = CH1_PWM ** 16004 is better and will give you the result in steps of 0.1% as show before.
    Oct 2009
    Yeah, sorry... the PCA chip has 4096 steps, so that's 0 to 4095. - brain fade - Must be my age
    Changing the value to 1601 works a treat - Can you explain how that works ?
    I feel I've written about the */ and ** so many times I've lost count, it's also described in the manual, but it's apparently one of those things...so here goes:
    The ** multiplies the two values you give it. This results in an intermediate 32bit result. PBP then returns the top 16bits of those 32bits. This means it does an inherent divide by 65536 so you COULD think of the ** operator as a "multiply by units of 1/65536 command".
    So x = value ** 1601 is PBP lingo for x = value * 0.02443 and what's 4095*0.02443? Correct, it's 100.
    How did I find 1601? Well you want an "output value" of 100 for an "input value" of 4095 so, (100/4095)*65536=1600.39 but since you really wanted it to display 100 and not 99 we had to round that up to 1601. Same thing for the 0.1% resoultion, then we need to round it up to 16004.
    I hope that makes sense.
    EDIT: Forgot, the */ and ** works slightly different depending on if you have LONGs enabled or not. The above describes how it works when DON'T have LONGs enabled.
    Oct 2009
    Many thanks, and sorry for making you have to repeat yourself ;-)
  1. Displaying strings from codespace.
    By Byte_Butcher in forum mel PIC BASIC Pro
    Last Post: - 28th March 2010, 21:32
  2. Displaying Weather Statistics
    By Bill Legge in forum Off Topic
    Last Post: - 12th October 2009, 10:09
  3. Displaying temperature Setpoints
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 27th October 2008, 15:52
  4. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  5. Displaying numbers
    Last Post: - 21st March 2006, 00:14
