Data from DS1307 (BCD) saved to ext memory and read back to display
Results 1 to 11 of 11
    Default Re: Data from DS1307 (BCD) saved to ext memory and read back to display
    Malcom is nearly correct
    I2Cwrite SDApin,SCLpin,$insert address of eeprom,[TimeH,TimeM,SS]
    should be
    I2Cwrite SDApin,SCLpin,$a0,eprom_location,[TimeH,TimeM,SS]
    where :- for a 24lc64 8k bytes and 32 byte page size
    1. eprom_location must be a word var
    2. eprom_location must be < 8192
    3. ( eprom_location//page_size ) < (32 -number_of_bytes to write ) ie don't try to write past a page boundary
    ps can't see the need for bcd - bin - bcd conversions though
    Oct 2009
    Hi Richard, nice to know I was almost there
    Roger stated that the RTC uses BDC format, which needs converting
    Data from DT1307 is in BCD format and data conversion, that's where I think I'm wrong, is not my cup of tea
    I presume that once you've converted the BDC format and stored them into variables as decimal values for hours and minutes you would then simply write those to the external memory, although they would need to be word variables, so would this be correct ?
    I2Cwrite SDApin,SCLpin,$a0,eprom_location,[TimeH.lowbyte, TimeH.highbyte,TimeM.lowbyte, TimeM.highbyte,SS.lowbyte, SS.highbyte]
    Assuming TimeH, TimeM and SS are all declared as word variables
    SWITZERLAND (french speaking)
    Default Data from DS1307 (BCD) saved to ext memory and read back to display
    Quote Originally Posted by Scampy View Post
    ...you would then simply write those to the external memory although they would need to be WORD variables...
    I thought only the address variable must be WORD sized?
    Name:  2016-07-20 20_41_53-Memory-24LC64_serial-I2C-EEPROM.pdf - [24AA64_24LC64 64K I2C Serial EEPROM] .jpg
    Roger
    Well,
    I'm still making some mistake somewhere.
    The display says now "55:55:55".
    If I bypass the I2CWRITE and I2CREAD commands, everything is fine
    ' PIC 16F690 Fuses (MPASM)
    @ __Config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
    OPTION_REG = %10000000 'PORT A&B Pull-Ups disabled (look WPUA & WPUB) INTEDG rising edge on A2
    'OSCCON     = %01100000 'Internal RC set to 4Mhz - not to be used with XTal
    ANSEL      = %00000000 'Analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Analog inputs Channels 8 to 11
    ADCON0     = %00000000 'A/D Module is OFF
    CM1CON0    = %00000000 'Comparator1 Module is OFF
    CM2CON0    = %00000000 'Comparator2 Module is OFF
    INTCON     = %00010000 'INTerrupts CONtrol
    TRISA      = %00000100 'Set Input/Output (0 to 5)
    PORTA      = %00000000 'Ports High/Low (0 to 5)
    TRISB      = %00010000 'Set Input/Output (4 to 7)
    PORTB      = %00000000 'Ports High/Low (4 to 7)
    TRISC      = %00000000 'Set Input/Output (0 to 7)
    PORTC      = %00000000 'Ports High/Low (0 to 7)
    ' Defines
    ' Variables
    SQW     VAR PORTA.2 ' RTC 1Hz output
    D_Out   VAR PORTB.7 ' serial data out
    SCL     VAR PORTC.0 ' RTC clock
    SDA     VAR PORTC.1 ' RTC data
    RTC_Sec VAR BYTE    ' Seconds (00-59)
    RTC_Min VAR BYTE    ' Minutes (00-59)
    RTC_Hou VAR BYTE    ' Hours (00-23)
    D_Bps   CON 16468   ' 9600 Driven Inverted None
    ' Initialize
    PAUSE 1000                      ' power-up serial-LCD
    SEROUT2 D_Out,D_Bps,[27,"C",0]  ' set serial-LCD cursor OFF
    SEROUT2 D_Out,D_Bps,[27,"L",0]  ' set serial-LCD backlight OFF
    ' Program
    ON INTERRUPT GOTO Read_DS1307
    MAIN:
        GOTO MAIN:
    ' Interrutp Service Routine
    DISABLE
    Read_DS1307:
        I2CREAD SDA,SCL,$D1,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        ' Convert Hex coded to decimal
        RTC_Sec = (RTC_Sec & $F)+((RTC_Sec >> 4)*10)
        RTC_Min = (RTC_Min & $F)+((RTC_Min >> 4)*10)
        RTC_Hou = (RTC_Hou & $F)+((RTC_Hou >> 4)*10)
        ' Write to external memory
        I2CWRITE SDA,SCL,$A0,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        PAUSE 10
        'Read from external memory
        I2CREAD SDA,SCL,$A0,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        SEROUT2 D_Out,D_Bps,["Time: ",DEC2 RTC_Hou,":",DEC2 RTC_Min,":",DEC2 RTC_Sec,13,10]
        INTCON.1 = 0
        RESUME
    ENABLE
    Roger
    Sep 2009
    Address should be word or byte variable, not constant.
         MemAdr var word
        MemAdr =0
        I2CWRITE SDA,SCL,$A0,MemAdr ,[RTC_Sec,RTC_Min,RTC_Hou]
        PAUSE 10
        I2CREAD SDA,SCL,$A0,MemAdr ,[RTC_Sec,RTC_Min,RTC_Hou]
    EDIT:
    Constant works for clock, as PBP send minimum 8 bits, but it wont work for EEPROM as it expecting 16bits.
    I mention that in another topic.
    Okay, I haven't declared the address as a variable at all.
    So I'll give it a try a little later (I'm in the office right now).
    ...your external eeprom is expecting 16 bit values for the data.
    This is confusing me. I think the 24LC64 needs data in BYTE format as where it's addresses are in WORD format.
    Roger
    That is correct. The 24LC64 data is 8 bits wide per individual location. CH1_PWM.lowbyte,CH1_PWM.highbyte is the correct way to sequentially load data into the eeprom if the variable is a word.
    EN82fn
    Oct 2009
    I have a project that sends values from 0 to 4096 to an 16 channel PWM led driver chip, and this is a sample line of code
      I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,CH1_PWM.lowbyte,CH1_PWM.highbyte]
    The reference to word variables I made was because your external eprom is expecting 16 bit values for the data, hence my reference to making your TimeH, TimeM and TimeS word variables, and trying the lowbyte / highbyte approach. - Like I mentioned in my first reply, I'm no expert, and this may be taking you off tangent, but then again, might be worth trying
  1. Replies: 2
    Last Post: - 3rd January 2013, 16:57
  2. DS1307 - How to store Decimal Value & how to convert back to BCD?
    Last Post: - 2nd January 2011, 23:44
  3. loading data to EXt. eeprom
    By MINHLE in forum General
    Last Post: - 28th December 2009, 17:56
  4. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 11:46
