Hserout sends wrong values
Results 1 to 8 of 8
    Default Re: Hserout sends wrong values
    xtal used is ?
    May 2016
    xtal used is ?
    It's a 24 mhz xtal.
    the default config is for a 20mhz xtal which gives a fosc of 48mhz
    to use a 24 MHz xtal change plldiv to 6 for a 48mhz fosc or turn the pll off .
    24 mhz into the pll @ plldiv5 is out of device specs.
    with pll off and cpudiv=1 fosc=24mhz fo a 24mhz xtal.
  1. Why does this PBP statement post the wrong time values?
    Last Post: - 22nd November 2011, 04:10
  2. Replies: 7
    Last Post: - 22nd February 2011, 21:20
  3. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  4. PIC16F877 sends/receives data to/from a PC
    By ovidiu in forum Serial
    Last Post: - 2nd December 2006, 15:09
  5. Wrong values with COSINE!
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 17:59
