12f638 simple temperature monitor
Results 1 to 7 of 7
    Jan 2013
    Texas USA
    Default Re: 12f638 simple temperature monitor
    Just a couple of ideas.
    1. You have no pause in your main loop so you are polling the DS18B20 extremely fast. You may want to try a Pause 1000 (1second) in between you gosub start_Convert and your goto mainloop.
    2. Your If/Then LED logic in start_Convert will only light the LED when the temperature is below 70 degF.
    if F_temp =>70 then
    low LED
    high LED
    TABSoft
    Jan 2008
    Pennsylvania
    Tabsoft, Thanks...... I tried the pause but doesn't seem to have any effect. I have my LED reversed at the moment so low LED should actually turn it on when it gets above 70. Just for giggles I moved the LED up to GPIO.0 and it works perfectly. I think I am not initializing GPIO.2 correctly.... When I did have the LED blinking very dimly the blink seemed to corresponded to when the LCD was getting data sent to it on GPIO.1... it seemed to blink the same time the LCD would flash when updating. Perhaps I can't use GPIO.2 for an output to light the LED.
    Quote Originally Posted by Tabsoft View Post
    if F_temp =>70 then
    low LED
    high LED
    Oct 2009
    Utah, USA
    Davy,
    Our dearly departed Darrell Taylor (world class programmer, *(my opinion)) left us with this little tidbit...
    it's an include file that will set most any PIC's pins to "all digital"
    just put this file in the same directory as your code and then put this line somewhere near the top of your code
    INCLUDE ALLDIGITAL15.BAS
    you may need to eliminate other attempts to turn off analog's so they don't confilict.
    Note: the 15 in the file name indicates that it is his version 1.5
    I hope this helps and that I haven't led you astray as I am not the greatest programmer
    Dwight
    Jan 2013
    Texas USA
    Try these settings:
    OPTION_REG = $FF
    INTCON = $00
    PIE1 = $00
    PCON = $10
    ANSEL = $00
    CMCON0 = $07
    TRISIO =$00
    WPU = $00
    IOC = $00
    CCP1CON = $00
    ADCON0 = $00
    Change this "LED CON 2 ' pin 5 for led indicator" to this
    "LED var GPIO.2"
    TABSoft
    Sep 2010
    Las Vegas, NV
    You can use GPIO.2 to light an LED if properly designed. I don't know much but I know that. Since you moved it to GPIO.0 and it worked then it should be designed correctly.
    I think tabsoft has it right to change LED to LED var GPIO.2
    Ifn that doesn't work can you show schematic?
  1. cheap and simple way to measure temperature
    By Heckler in forum Schematics
    Last Post: - 7th March 2011, 23:56
  2. AC main monitor
    By tallen in forum mel PIC BASIC Pro
    Last Post: - 25th August 2009, 17:23
  3. voltage monitor
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 17th August 2007, 10:57
  4. Baby Monitor
    By inoonan in forum Serial
    Last Post: - 14th September 2006, 23:54
  5. Car monitor
    Last Post: - 27th March 2006, 19:13
