Hserin/out BYVAC serial LCD
Results 1 to 6 of 6
    Default Re: Hserin/out BYVAC serial LCD
    From the looks of it you have a terminator character 06, so use the STR see manual
    "STR followed by a byte array variable, count and optional ending character will receive a string of characters. The string length is determined by the count or when the optional character is encountered in the input."
    So regardless of how many characters you are expecting put into the command the MAX COUNT characters it will return and then the optional ending character.
    Then all you need to do is look down the array and pick out the value you need - the 06 is the terminator.
    Quote Originally Posted by aerostar View Post
    Thanks aerostar
    something like this:
    get_key:
    hserout ["rg", 13]
    Hserin 1000, start, [STR char\4\$06] '
    pause 10
    if char[0] = $30 then
    goto get_key
    char[0] = char[0] - %110000
    char[0] = char[0] << 6
    char[1] = char[1] - %110000
    char[1] = char[1] << 4
    char[2] = char[2] - %110000
    b0 = char[0]+char[1]+char[2]
    lookdown b0, [101,184,183,181,162,161,153,208,201,199,177,149,19 5,89,102,99],keypressed
    hserout ["rdkey= "dec keypressed,13,10]
    pause 10
    is it possible to simplify the pressed key number ?
    Thing to do is try it and see if it works ! I do not see 238 in your lookdown table, you said key 1 returns 238
    converting your bytes so
    char(0)=$32
    char(1)=$33
    char(2)=$38
    char(0) = (char(0)-$30) * 100 'answer 200
    char(1) = (char(1)-$30) * 10 'answer 30
    char(2) = char(2)-$30 'answer 8
    b0 = char(0)+char(1)+char(2) 'answer 238
    compiles but not tested !
    Hi
    Thanks for the char handling
    thisone is working perfectly
    hserout ["rg", 13]
    Hserin 1000, start, [STR char\4\$06] ' Get a char from serial port
    pause 10
    goto get_key
    serout2 tx,84,[dec char[0]," ",dec char[1]," ",dec char[2],13,10]
    serout2 tx,84,[dec b0,13,10]
    lookdown b0, [125,238,237,235,222,221,219,190,189,187,231,215,18 3,119,126,123],keypressed
    serout2 tx,84,[dec keypressed,13,10]
    pause 10
    Hserout ["rc1", 13] ' Send text followed by carriage return and linefeed
    pause 10
    Hserout ["rd","key= ",dec keypressed,13]
    'keypressed = 0
    pause 10
    If this is in a subroutine and get_key is not in the subroutine then you will get problems by not using RETURN, do not jump out of a subroutine.
    goto get_key
  1. pic16f88 Serial questions (hserin/hserout, etc.)
    By harralk in forum mel PIC BASIC Pro
    Last Post: - 28th October 2012, 00:29
  2. serial port interrupt without using hserin
    By cluster in forum Serial
    Last Post: - 27th September 2011, 14:56
  3. PIC16F88 HSERIN to LCD Problem
    By robbrownuk in forum mel PIC BASIC Pro
    Last Post: - 6th June 2009, 22:32
  4. parallel LCD to serial LCD
    By maxbao in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 11:44
  5. to convert LCD // hd 44780 --> serial LCD
    By in forum mel PIC BASIC Pro
    Last Post: - 15th March 2003, 12:37
