HOW DOES PBP handle bits varables to bytes
Results 1 to 9 of 9
    Default Re: HOW DOES PBP handle bits varables to bytes
    bit_byte1 var byte
    bit0 var bit_byte1.0
    bit1 var bit_byte1.1
    bit2 var bit_byte1.2
    bit3 var bit_byte1.3
    bit4 var bit_byte1.4
    bit5 var bit_byte1.5
    bit6 var bit_byte1.6
    bit7 var bit_byte1.7
    uses 1 byte
    mybit var Bit
    uses 1 byte
    mybit0 var Bit
    mybit1 var Bit
    I think uses 2 bytes .
    you can verify this by checking your ????.lst file after compiling ????.pbp
    [COLOR="#00FF00"]bit_byte1 var byte
    mybit0 var Bit
    mybit1 var Bit
    Not necessarily. Compiler makes best use of memory and packs the bits in bytes when possible.
    So if you declare the above bit variable, they are going to be in one byte. The ninth bit will be in new byte location.
    Last Post: - 14th June 2016, 07:55
  2. Configuation bits setting in PBP
    By Max_Gauss in forum mel PIC BASIC Pro
    Last Post: - 8th September 2010, 18:25
  3. Pickit 2 saving varables?
    By jessey in forum Off Topic
    Last Post: - 7th June 2010, 09:14
  4. 16/32 bits PIC support in PBP?
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 9th May 2010, 15:40
  5. Bits & Bytes
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 11:52
