Word Variable and I2C
Results 1 to 9 of 9
    Oct 2009
    Default Re: Word Variable and I2C
    Just remove the >> 8 part of it and see if it works.
    Henrik,
    I just tried that with the the following:
    pcaChannel = 0                                              ;Set a PWM channel
    pcaPwmValue = B_PWM                                         ;Send current value
    lcdout $FE,$D4+0,"PWM ",dec pcaPwmValue
    i2cControl = $6 + 4*pcaChannel                              ;LED0_ON_L $6
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,1,pcaPwmValue]
    I've run a test and that seems to work in as far as the LED on channel 0 fades up. What I did notice though was that the LCD continued to count up past 4095. Notice I placed a 1 as the value for the "ON" setting following Steve's comments. I'm hoping that is correct ?
    I'm re-running the test as I missed the point where the LED on channel one went off. I'm hoping that it was when the value was close or exactly 4095, as at least that would prove the range that is being accepted. Just need to figure out how to specify the size of the variable as you suggest - any pointers ?
    I don't know, I haven't read the datasheet for the device you're using, I only commented on the use of I2CWRITE from a general perspective.
    Not sure I understand... I've never used I2C but I'm pretty sure that, unlike SHIFTOUT, the transactions are always in bytes. In other words all transactions are in multiple of 8bits. If the device you're talking to is actually USING 1 or 7 or 12 or 14 bits out of the 8 or 16 you send is completely up to that device. However, if the device specify a range from 0 to 4095 then actually SENDING it value outside that range would/could result in unexpected things. Again, I haven't read the datasheet for the device in question.
    As the documentation for I2CWRITE says, specifying a BYTE variable will send a byte variable, specifying a WORD variable will send a WORD variable (two bytes, high byte first).
    If you want to prevent the value you're sending from ever going above 4095 you can, for example, AND it with 4095.
    Oct 2009
    Henrik, thanks again for the reply.
    Using the code in my last post (#5) the LED on channel 1 of the PCA chip fades up, all the way until pcaPwmValue reached 4096. At 4097 it went off, and as it increased (now at 6745) the LED on channel 1 has lit up but not on full brightness. What I can't understand is I have a B_MAX variable which has a value of 4095, with an "If B_PWM=B_MAX then doe something else statement which seems to be ignored. I was reading up on the variable statement and the manual comments that there is a size statement, with the use of additional modifiers, but I couldn't find any decent examples. Is there a way of simply limiting the word to 4095 something like B_PWM VAR Word size 4095 ??
    Two ways that I can Think of right now, your way which you've somehow implemented wrong and the way I tried to explain in my previous post.
    IF pcaPwmValue >= 4095 THEN pcaPwmValue = 4095   ' Clamp value at 4095
    LCDOUT $FE,$D4+0,"PWM ",dec pcaPwmValue
    Or....
    pcaPwmValue = (B_PWM & 4095)    ' Roll over value at 4095
    By your explaination it sounds as if the PCA chip is basically doing what the second approach above does, ie start over at 4096 and again at 8192 and again 12288 and so on.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by Scampy View Post
    Henrik,
    You are missing some of the detail contained in the user manual.
    If you have not set Auto Increment on your i2cwrite is sending 0 then 0 then 1 then pcaPwmValue to $6.
    To test this change your code to
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[pcaPwmValue]
    If I am correct in my interpretation it is also possible that you are only changing the first 8 bits as the 4 upper bits are address $7.
  1. Stumped with word variable
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 11th November 2013, 14:11
  2. Word variable and storing correct value
    Last Post: - 28th December 2012, 13:04
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. adding new word variable ?
    By iugmoh in forum General
    Last Post: - 21st February 2008, 01:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
