Wrapping code
Results 1 to 14 of 14
Thread: Wrapping code
    Default Re: Wrapping code
    Quote Originally Posted by ruijc View Post
    Hi there,
    yes there is...
    just use the _ to break the line.
    Check this example:
    Lookup y, [$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
    $00,$00,$10,$08,$00,$00,$00,$00,$80,$80,$90,$00,$20,$1C,$2C,$30,_
    $18,$18,$1C,$1C,$3E,$2E,$2A,$08,$2C,$10,$18,$18,$08,$00,$00,$00,_
    $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F0,_
    $F0,$02,$02,$04,$04,$04,$04,$00,$00,$00,$00,$00,$01,$00,$00,$00,_
    $00,$00,$00,$00,$00,$80,$80,$80,$80,$40,$40,$40,$20,$20,$10,$10,_
    $10,$08,$88,$88,$4C,$44,$C4,$A4,$02,$00,$00,$00,$FC,$8C,$C4,$00,_
    $00,$00,$00,$00,$00,$00,$20,$68,$68,$38,$00,$00,$00,$00,$00,$E0,_
    $20,$10,$B0,$68,$C8,$00,$00,$80,$30,$C8,$08,$00,$00,$00,$00,$00,_
    $00,$00,$00,$00,$00,$FE,$01,$11,$C1,$A8,$88,$88,$54,$D4,$00,$00,_
    $00,$00,$00,$00,$00,$00,$02,$14,$01,$0D,$0A,$6A,$10,$00,$00,$00,_
    $F7,$39,$18,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
    $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$4E,_
    $00,$00,$00,$03,$EE,$01,$01,$03,$01,$F3,$45,$C3,$60,$D7,$BE,$46,_
    $00,$00,$00,$00,$00,$00,$00,$00,$00,$3F,$00,$14,$2C,$8A,$4A,$56,_
    $19,$06,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$02,$0C,$02,$00,_
    $00,$80,$00,$00,$02,$01,$03,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
    $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$80,$00,_
    $80,$80,$00,$31,$00,$00,$00,$00,$FF,$00,$00,$00,$00,$DE,$39,$38,_
    $08,$6B,$FC,$32,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
    $00,$02,$01,$00,$00,$00,$00,$00,$00,$80,$80,$40,$40,$40,$20,$20,_
    $20,$10,$10,$18,$08,$04,$05,$01,$00,$00,$00,$00,$00,$00,$00,$00,_
    $00,$00,$02,$05,$06,$03,$00,$00,$08,$10,$10,$20,$20,$20,$24,$56,_
    $5C,$80,$80,$81,$83,$89,$00,$00,$00,$00,$80,$C0,$50,$48,$28,$2C,_
    $12,$12,$10,$08,$08,$08,$04,$04,$02,$02,$03,$01,$01,$00,$00,$00,_
    $00,$00,$00,$00,$00,$00,$00,$00] ,LcdReg
    regards
    Rui
    I'm not sure that works on anything other than the example.
    Norm
    Norm
    Maybe you could phrase that the other way around, and suggest a scenario where it doesn't work?
    I thought the maximum allowed number of constants for LOOKUP was 255, it looks to be way more than that it the list - has that changed?
    Never the less, it does show the "line continuation".
    OK, I'll do my best to clarify that myself.....
    Previously the limit was 255 or 256 but in version 2.5C the limit for PIC18 parts was increased to 1024 entities. The PBP3 manual (which of course is the correct place to look when in doubt) says 1024 for PIC18 parts while the online help in MCSP 5.0.0.3 doesn't mention that, it says 256 for 18C parts though.
    Dec 2010
    While the manual doesn't say a lot about how to use the line extension character, from experience you need to extend from an operator and not just anywhere in the line.
    For example:
    myvariable31 = myvariable1 + myvariable2 + myvariable3 +_
    myvariable4 + myvariable5
    should work.
    However;
    myvariable31 = myvariable1 + myvariable2 + myvar_
    iable3 + myvariable4 + myvariable5
    will not.
    It's called a line extension, but it's really statement extension to include terms and operators on the following line. You can't just jam it anywhere in the line of text and have the next line pick up exactly where the first left off.
    My bad. Pleased to see it works OK.
    Norm
    New Jersey
    I have one.
    I can't code wrap when the characters extend past column 255 even though we're given 1024.
    Could you explain what you mean by that.
    This code which goes out to column 333 compiles just fine with PBP3.
    I     VAR WORD
    value VAR WORD
    LOOKUP I, [$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,$45,$35,$67,$7E,_
    $8F,$00,$0F,$C0,_
    $EF,$55,$01,$00], value
    It wraps in the forums code box, but you should get the idea.
    New Jersey
    What happens when you try to compile this code?
    HSEROUT ["iVBORw0KGgoAAAANSUhEUgAAACEAAAAkCAYAAAAHKVPcAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsQAAA7EAZUrDhsAAArtSURBVFhHVVhpb1XXFfVfaACPb579bGYwHvBsP9vPfp6NzGDjCcJghkClpKSIUmVom1aKKqVRUtqilhZwmANUplUSNUOhqIRIQYKUqimhUMKPWF1rn3fd5MN9w7nn7",_
    "nHttfe5BQFfCXylhSgrWYIyfgf1n79DZYV2+UsWI+Avht9XjJLixQj5eb+siFehffvzv/Ws31dke7Wu/wFeYe3ht3TovtbtHuXpW3sL7AEK9Ba8Db5SGsKNft2jUd8U4hkdpkFSYJcMpqxSGi0Dy/i81oNU7CvV+hJTrHvOGN6XgVwrcMp58cay8ti3LBzMtlJA3hgKichT/tcV5jNBKvxpf9Z+",_
    "B3hfUXMRXIKgKXGetjfWIhQopTOLbe3F2RkXzXxUCmThkf07EeYmGRMOliHIkAZpYUCecnOYys/um8KpTAPme1pweO1yRIsW4RdVK/GnjhacymUQ4f+/",_
    "PjeO8z2NmG9bjxNtDWaY5CmFumSAIqNIRLgeDpaafEaCG2lAeSyE8kTYLD5MS20tGbHNIVp8elMvHk0P4el4H25PDuBMWx2ut9fjK659NDOKBPFyqa0WD2cG8HhzD66PdOP1nZNmRJqyo6EyRlnKS1FBueXxsMmW4wWyyuW7GCEuet4LYHYpBQzjq001+HQgi/sbe3FxpBMJGn+hdT1uTg/",_
    "XibVX6mVPtMoHvzotJcMCrfzp2Bbp97K+POKB7WvEOxPa9oc9//AEEBNtPX0IZcAAAAAElFTkSuQmCC",34,"/>"]
    Compiling that code ... generates a "FATAL ERROR: Internal: Locate could not find nCmd = 32174784"
    But it has nothing to do with "Line Continuation" and the "_" underscore.
    There are simply too many characters in the HSEROUT command.
    If you break that into 2 HSEROUT statements, it compiles fine ...
    "B3hfUXMRXIKgKXGetjfWIhQopTOLbe3F2RkXzXxUCmThkf07EeYm"]
    HSEROUT ["GRMOliHIkAZpYUCecnOYys/um8KpTAPme1pweO1yRIsW4RdVK/GnjhacymUQ4f+/",_
    If you add a single character to the first HSEROUT ... it will fail.
    Because there are already 512 characters. Apparently, the maximum it can handle.
  1. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  2. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
