Overwriting previous address contents... oh no - not again!
Results 1 to 8 of 8
    Feb 2014
    Aarhus, Denmark
    Default Re: Overwriting previous address contents... oh no - not again!
    Via Google Translate:
    Very interesting, Darrel: Blink.pbp works for 16F88! It's only 18F that are affected by the problem.
    Okay, here's a longer program (DisplayRouter.pbp) I have written that I Regularly inspect uploaded to my PIC18F45K22. It has now run for several months. Now it will not compile anymore ...
    What is interresting is that I do not get exactly the same error message every time I compile it ...!
    No, I do not have Office 365
    But I have Office 2007 Home & Student + Access 2007 and Outlook 2010
    The problem arose for me when I included this module: http://support.melabs.com/threads/79...ze-Version-3.0 and tested it in my own code.
    Do not know if it may have been something going on ...
    I also tried with MPLAB 8.9 8.88 8.92 and so on. Same problem.
    It's like being hit by fate ...
    - Jacob
    Quote Originally Posted by PerlNoerd View Post
    Then here's what you will find ...
    If you open the .LST file (after compiling for an 18F), and scroll down to the end of the code (just before the symbol table), you should see that the errors happen at the assembly language END statement.
    This is AFTER all of PBP's code.
    It will look something like this ...
    Error[118]  : Overwriting previous address contents (0000)
    Error[118]  : Overwriting previous address contents (0001)
    Message[303]: Program word too large.  Truncated to core size. (002E1888)
    Error[154]  : Each object file section must be contiguous (section .config_000000_3LINE.O)
                          00223         END
    If you search the Microchip forums for ""Each object file section must be contiguous" you'll see that many people have had the problem.
    I don't think anyone has ever isolated what actually causes it, but it appears that some programs install a new common file in the OS that breaks MPASM.
    Office 365 seems to be one program that causes it, but there may be others.
    It doesn't matter what you have in your code, and it was just coincidental that you used the CODE_SIZE module when you noticed the problem.
    I'm sorry, but the only fix seems to be re-installing the OS, and being careful what you install, or checking MPASM after you install anything.
    Please keep in mind that this is not a problem with PBP.
    Hi Darrel,
    Does the problem also show up with MPASMX ?
    Feb 2014
    Aarhus, Denmark
    Hi Darrel
    You are right about the .LST file. It looks approximately like this.
    It is a sad problem. I certainly do not have the energy to re-install Windows 8 with all programs and settings. But I love PicBasic Pro and the little 8-bit PIC microcontrollers so I will not give up this time ...
    Here is my solution to the problem, for those who may be interested:
    I installed a Windows 7 x64 SP1 in VMware Player. It runs with Host-only network (a private network shared with the host). It does not download any updates to Windows. I install only PBP3, Microcode Studio Plus 5, MPLABX 2.0 and PICKit2 burning software.
    And above all: I keep a working copy of the system I can use if the problem shows up there.
    Now it runs fine there.
    - Jacob
    Yes, the problem affects MPASMX too, which as I understand it is the same program as MPASMWIN but development continues with that version. MPASMWIN is now static.
    Jacob
    That's a great solution!
    I will have to suggest that in the future. Thanks.
  1. Replies: 4
    Last Post: - 8th May 2012, 07:00
  2. PBP v3.0 vs previous versions
    By MikeBZH in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 22:30
  3. Replies: 8
    Last Post: - 3rd March 2011, 23:20
  4. Saving variable(s) contents before power is removed
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 18:26
