Shiftin problem (16f877A with MCP3201)
Results 1 to 4 of 4
    Default Re: Shiftin problem (16f877A with MCP3201)
    I think you need mode 4 in the SHIFTIN.
    And it needs to shift 16 bits, not 12. Even though it's a 12-bit result.
    A few other changes and ... try this ...
    #HEADER
        ERRORLEVEL -306			; SUPRESS PAGE BOUNDRY ERROR
    #ENDHEADER
        __CONFIG _XT_OSC & _WDT_OFF & _LVP_OFF & _CPD_ON & _CP_ALL & _PWRTE_ON & _BODEN_ON
    DEFINE DEBUGIN_REG	PORTC
    DEFINE DEBUGIN_BIT	7
    DEFINE DEBUG_REG	PORTC
    DEFINE DEBUG_BIT	6
    DEFINE DEBUG_BAUD	2400
    DEFINE DEBUG_MODE	1
    '-- MCP3201 pins
    CLK	  Var PortE.0
    DIN   Var PortE.1
    CS	  Var PortE.2
    Calibration  CON -1            ; Signed value in 0.1 deg. C
    Sensor       VAR WORD
    ADCON1 = 7
    CMCON = 7
    HIGH CS
        LOW CS
        SHIFTIN Din,Clk,4,[Sensor\16]
        HIGH CS
        Sensor = (Sensor & $FFF) * 5000
        Sensor = DIV32 4095 + Calibration
        IF Sensor <= 1500 THEN DEBUG DEC Sensor/10,".",DEC1 Sensor,13,10
        PAUSE 1000
    Goto Main
    Thanks a lot for the help. It is working. But could you explain my doubts please?
    I understand why clock idles high (as data comes on falling edge), BUT why read before sending clock mode?
    Should this be a normal practice or is there something I missed?
    Calibration  CON -1            ; Signed value in 0.1 deg. C - Not sure what this does?
    Sensor       VAR WORD
    HIGH CS
        LOW CS
        HIGH CS
        Sensor = (Sensor & $FFF) * 5000 ' Understand the first part, we masked the high 4 bits and force them to 0 BUT I dont get the remaining maths, like Why times by 5000? and what does the below statement do
        PAUSE 1000
    Goto Main
    ___________________
    WHY things get boring when they work just fine?
    _____ _____ _____ _____ _____ _____ _____ _____
    The need for 16-bits comes from the MCP3201 datasheet ...
    I didn't overthink the mode number. Just tried different ones till it worked.
  1. SHIFTIN SHIFTOUT timing problem
    Last Post: - 11th April 2011, 21:08
  2. Problem with 16F877A but not with 16F876A
    Last Post: - 16th May 2008, 14:18
  3. 16f877A and shiftin shiftout
    By ghdsfier8 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2008, 13:47
  4. SHIFTIN problem
    By champion in forum mel PIC BASIC Pro
    Last Post: - 29th January 2007, 03:31
  5. 16F877A HSERIN problem
    Last Post: - 30th October 2006, 02:51
