Noob needs some help please...
Results 1 to 12 of 12
    May 2008
    Default Re: Noob needs some help please...
    I don't follow... can you give a quick example?
    Dec 2010
    In most programming languages, when you GOSUB, a number of registers get stored in memory to free them up for use by the subroutine. When you RETURN, those values are put back so the program can continue where it left off. When you GOTO out of a subroutine, the registers are not restored. If you did this when writing a program in a Windows or Linux environment, where the values are store in program RAM, the memory is not released when you GOTO out of the subroutine. This is called a memory leak in your program. Do this often enough, and all the RAM is used and not released until a reboot. It's a good habit to always return from a GOSUB with a RETURN to prevent this.
    Apr 2007
    Pennsylvania, USA
    I had a similar routine once and it worked fine, until the 23rd time pressing the button it would cause the pic to reset. As Demon said, just have the button set a bit to 1 then return. Immediately after the gosub check if the bit is a 1 and if it is then goto wherever you want.
    Shawn
    Quote Originally Posted by Neosec View Post
    Flag=0
    Gosub routine
    If flag = 1 then goto somewhere
    Routine:
    Bla bla bla
    If something then flag = 1
    May 2008
    OK, got it. Thanks to everyone for the input.
  1. PICKit2 vs. JDM (Noob question)
    By loamobn in forum General
    Last Post: - 19th September 2010, 19:19
  2. NOOB in need of help
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 00:01
  3. Help a noob out?
    By yasiryassin in forum mel PIC BASIC
    Last Post: - 15th January 2008, 07:37
  4. (noob)hello world?
    By m4gill4 in forum mel PIC BASIC
    Last Post: - 30th November 2007, 01:23
  5. Uber noob needs clarity!
    By bill12780 in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2007, 22:40
