18F87J50 message question
Results 1 to 12 of 12
    Sep 2009
    Default Re: 18F87J50 message question
    I don't know... It could be any thing...
    Did you try to use DT HID?
    New Jersey
    You mean to write my code? No. I used it to verify my code is an issue.
    Sep 2009
    Then try it
    New Jersey
    I did before. If there was an error, VB would freeze and the program would close. Do you have that problem?
    Sep 2009
    I think that is same for pc app if you are using DT HID, or something else.
    Probably you have bug in your vb6 app.
    You have my app and code, try it... And from that buildup your code on both side.
    New Jersey
    I have four other VB6 programs that I made with the same version and they don't freeze up like this. When you are are programming and testing the VB6 software, what happens if you hit play and then about 5 seconds later hit stop? Does it stop and allow you to edit or will it freeze and crash?
    Sep 2009
    I don't have board right now to try it...
    I think it freezes, but that doesn't have anything with DT HID.
  1. HID USB on 18F87J50
    By pedja089 in forum USB
    Last Post: - 25th August 2011, 10:24
  2. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 15:26
  3. message 306
    By chip_select in forum mel PIC BASIC Pro
    Last Post: - 16th March 2008, 20:45
  4. 18F87J50 Success
    By GeoJoe in forum General
    Last Post: - 28th October 2007, 02:52
  5. SMS message
    By angelika in forum mel PIC BASIC Pro
    Last Post: - 17th June 2005, 15:47
