New approach to Rotary Encoder
Results 1 to 40 of 91
    Default Re: New approach to Rotary Encoder
    How does this work? Since Enc=Aux=0, How can the If clause be true? There must be some pull-ups in PORTA pins.
    Here's the initial approach, I've modified for my needs. It does not works, what may be the reason?
    LEFT var GPIO.0
    RIGHT var GPIO.1
    COUNTER VAR word
    counter=128
    cycl:
    if LEFT=0 then                 'here is switch 1 of the rotary encoder
        counter=counter+1
        goto lcd
    if RIGHT=0 then                 'here is switch 2 of the rotary encoder
        counter=counter-1
        goto lcd
    goto cycl
    lcd:
    hpwm 1,counter,5000
    while (LEFT=0 or RIGHT=0):pause 10:wend
    goto cycl
    MCU is PIC12F683
    well, I think I found the problem - it never treats inputs as inputs, despite a high level on LEFT or RIGHT, it still =0
    Seems like I need some command to configure pins as input?
    TRISIO=%11111111
    does not helps
    ANSEL = %00000000
    CMCON0 = 7
    this helped
    Sep 2009
    Sorry for the late reply
    See here and we will resolve the questions
    https://sites.google.com/site/proyec...le-con-16f628a
    It seems very strange that I got an e-mail notification only today about this thread by dovegroup's reply.
    I am not very good at C but from your example, dovegroup, I think the variable x might change more than one at every step in rotating the encoder because of the bouncing effects.
