DHT11 Temperature/Humidity sensor
Results 1 to 6 of 6
    Aug 2008
    Portugal
    Default Re: DHT11 Temperature/Humidity sensor
    While "pasting" existing projects ...
    you could download the example programs Mikroelektronika gives in the SHT11 module apps ...
    there's a Mikrobasic example you could translate much easier ...
    Hi Alain;
    SHT11 is not the same as DHT11, they are much different!
    Thanks and Regards;
    Gadelhas
    Hi
    yes SHT11 is I2C device (data/clock)
    SHT11 have one wire serial comunication.
    I still have not solved the problem, but this weekend we'll be working.
    I'll keep you informed.
    Many thanks
    Mirco
    Quote Originally Posted by gadelhas View Post
    Hi Alain;
    Hi Alain;
    Sure protocols are quite different !!!
    but handling comms with PBP "already cooked" functions is very similar, if you have a closer look at it ...
    just need a little effort ...
  1. Replies: 6
    Last Post: - 14th October 2013, 13:27
  2. Replies: 10
    Last Post: - 17th February 2012, 08:19
  3. Sensirion humidity sensor
    Last Post: - 7th October 2008, 16:48
  4. Replies: 10
    Last Post: - 4th September 2008, 18:55
  5. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
