Lets look at what this is doing. First, let's start with what's in the EEPROM. Starting at Address $00 (I put _ as placeholders for the value $FF):Code:addr var WORD For addr = 0 TO 5 ' I2CRead memSDA,memSCL,$A1,addr,[STR TEXT\6] '$A0 does the same as $A1 pause 10 Next addr
The 1st time through the loop, addr = 0, the PIC sets the register address in the 24LC256 to $0000, then reads 6 bytes sequentially, and puts them into TEXT = "HELLO!"Code:0123456789ABCDEF $0000-000F: HELLO!__KM17WS__
The 2nd time through the loop, addr = 1, the PIC sets the register address in the 24LC256 to $0001, then reads 6 bytes sequentially, and puts them into TEXT = "ELLO!_"
The 3rd time through the loop, addr = 2, the PIC sets the register address in the 24LC256 to $0002, then reads 6 bytes sequentially, and puts them into TEXT = "LLO!__"
The 6th time through the loop, addr = 5, the PIC sets the register address in the 24LC256 to $0005, then reads 6 bytes sequentially, and puts them into TEXT = "!__KM1"
At least that's the way it should be working. I'm not sure why you got "M__KM1".
However, now hopefully you see why, when you changed the FOR...NEXT loop to count from 3 to 8, it gave you "KM17WS"
It's because on the last loop addr = 8, the register address set in the 24LC256 is $0008, then it reads 6 bytes sequentually, and you end up with TEXT = "KM17WS"
That help?
