Never seen this before!!
Results 1 to 5 of 5
Threaded View
  1. #2
    May 2006
    Del Rio, TX, USA
    Default Re: Never seen this before!!
    Quote Originally Posted by Megahertz View Post
    movlw   -97
    addwf   TMR0
    I have never come across any negative number getting loaded into a variable.
    Is this the same as Loading 159-> (256-97=159) to Timer0 ?
    It sure is.
    You can look at the .LST file after you compile the program and find the line for "movlw -97". You will see that it will be something like:
    00009E 0E9F 00232 movlw -97
    00009E <-- Address of the the instruction
    0E9F <-- Actual instruction code
    If you look up the MOVLW code in the PIC datasheet, you will see the OP-CODE (most significant 8 bits of the 16 bit instruction) is $0E (%00001110). The literal is the 8 least significant bits, $9F in this case (which is 159).
